Question about Proscan 32LA30Q Television
Proscan Model 26LB30QD purchased at bjs will not turn on. makes a noise which sounds like the dvd player then powers down.
    Genius:
  • 1,156 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on May 27, 2011
26LB30QD DVD Player says
reinstal dvd software again then check
May 16, 2012 | Proscan 26LB30QD 26 in. LCD HDTV
DVDs/CDs are NOT being recognized in the player.
Yes or you could use a seperate dvd player,probably cheaper than having it serviced
Feb 18, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Tv buzzs when power is off.
Return the production without any further delay.
Oct 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Oct 04, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
The DVD player has stopped working and is under warranity. What do I do?
Proscan is an Thompson Electronics Product (RCA) Most RCA service centers will fix proscan. check locally for an rca dealer.
Sep 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
I tried putting a dvd into the dvd player but it only goes in halfwayfor the proscran 26LB30QD
According to the owners manual, you have to call PROSCAN customer support for this problem. The PROSCAN customer support telephone number is. 1-888-977-6722. You can also go online to their website. www.oncorpus.com. Use the customer support section here to get help. I hope this has helped you with your problem.
Mar 12, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
26 inch Proscan with no manual
You can find the the manual in pdf form on the PROSCAN website. look under support for manuals and find the one you need and down load it for your use. The website is . www.oncorpus.com You can also call the PROSCAN customer support at this telephone number.1-888-977-6722. I hope this has helped you with your problem.
Mar 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote for tv
If your TV model number is 26LB30QD, it's $32.12 at remotes.com
Rate me if I answered correctly
Feb 02, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32LA30Q Television Logo
56 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
