Question about SIB 320GB 2.5 Inchs SATA HDD Hard Disk Drive for Acer Aspire 2920 5320 7730G 7736Z 7738 7738G 7740 7740G... Hard Drive
I cannot get my laptop to start. I have bought a new power cord, and it will not charge or start. I have an acer aspire 7736z. What could the problem be?
I had the same problemjust plug out the hdd turn on u'r pc it will work but there is no system (win7) bcz there is no hdd soo just plug in the hdd again it worked for me 100% i hope that too
saaalllaaaam :p
Posted on Jan 16, 2013
  • 1,591 Answers
Try removing the battery, it may be defective. Remove the battery and see if the unit powers up when plugged in.
Check to see if the charge light at least comes on when it's plugged in....if it doesn't, then the socket the power supply plugs into may need to be re-soldered.
Posted on May 27, 2011
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
Acer aspire 4339 wont turn on with new battery
That means the laptop is not detecting the battery as authentic or full enough to boot the laptop. Most batteries are now smart batteries, so the battery you bought may be an aftermarket battery not supported by the laptop. Return it and cite the issue.
Mar 03, 2014 | Acer Aspire AS43392618 PC Notebook
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Acer aspire 7736z on button flashing can not start
!- Disconnect from Power Adapter and remove battery
2- Press Power button for 5 seconds
3- Put the battery back and start the laptop
if this doesn't work check memory and/or mainboard, or bring it to a certified troubleshooter.
good luck!
Jun 02, 2011 | Acer Computers & Internet
Hello, I have an acer aspire 5741 which i bought 5 months back. The problem started a week back and has got worse. It is when i plug the cord for charging on laptop, the blue light on power button and...
it needs a new a\c power block inside they are cheap and semi difficult to repair i wouldnt think it would be over 100$ max but it isnt in my lap to inspect so this is my opinion ok
Dec 21, 2010 | Acer Aspire One PC Notebook
Manuels for Acer Aspire 7736Z-4448 Model No.
Hi
follow this link and hopefully you will find what you are looking for type in what you looking for
http://support.acer.com/
Nov 15, 2010 | Acer Computers & Internet
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
I have an acer aspire 3680 computer, Before the battery wasnt working so i bought a new one. Well now the battery came and i tried to charge it, but its not indicateing that its charging and won't charge...
Taking the fact that you already replaced the battery into consideration, chances are that you have a faulty cord. Looks like you're going to need a new one mate.
Sep 16, 2009 | Acer Aspire 3680 Laptop
Acer Aspire won't start
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Jul 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
SIB 320GB 2.5 Inchs SATA HDD Hard Disk Drive for Acer Aspire 2920 5320 7730G 7736Z 7738 7738G 7740 7740G... Hard Drive Logo
800 people viewed this question
Top SIB Computers & Internet Experts
Piyal Perera
Piyal Perera
Nathan
Bios Pro
Are you a SIB Computer and Internet Expert? Answer questions, earn points and help others
