Question about Kenmore Top Freezer Refrigerator
I have a top mount Kenmore refrigerator, model no. 106.60272990, serial no. EK2929089. It is about 10 years old and works fine except for one problem that has kept recurring every 2-3 months over the last 2 years. The drain in the back keeps freezing with water accumulating in the refrigerator. I keep using hot water to unfreeze the drain, but, as I said, the problem keeps recurring. I think it's the same problem that I've read other people having, and I've also read that it can be solved with attaching an alum. or copper wire/piece to the defrost heater. If that's the solution, I don't know where to find the heater. But before I do anything further, I thought I'd ask your expert advise. Instructions, how to get to the part(s) of the refrig/freezer to get the problem solved once and for all, would greatly be appreciated. Thank you very much. Barry
Hey barry I had the same problem and i recently broke down and called a repair service, the repair person installed a small aluminum piece he refered to as a heat probe, on the heater coil which is behind the back plate in the freezer, he claims this will solve the problem, evidently the water created in the defrost cycle freezes before it can get down the drain, thus the drain becomes blocked with ice, subsequent cycling of the heater for defrost causes more water and ice buildup and the water overflows through air ducts into the refridgerator, I would check at an appilance parts store for this part it cost $20, unfortunatley the total cost of the service call was $ 227, My gripe is this is an obvious flaw in design and should have beeen addressed by Kenmore, if you make a part to remedy a problem then its an admission of the problem! Good Luck!
Posted on Jun 02, 2011
What was production year of Kenmore Refrigerator series 60821, Model 106-8608260?
Hello Nancy;
My name is Peter. I am a retired field service refrigeration technician.
The production year is based on your unit serial number. Both the serial number and month and year of manufacture is on a label in your fresh food section, on the side wall near the top.
Jan 01, 2015 | Kenmore Refrigerators
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
I HAVE A KENMORE MODEL # 253.63732300 TOP FREEZER REFRIGERATOR. IT HAS BEEN IN STORAGE FOR 2 YEARS. I GOT IT OUT AND PLUGGED IT UP TO USE IT BUT NOW THE FREEZER & REFRIGERATOR WILL NOT GET COLD. WHAT...
Was the refrig on its side at any time during movement and if so , was it left standing for 24 hrs before turning on ?
Check the fans to see if frozen (rust ) from the humidity when unplugged . 1 in the freezer and 1 in the rear , cooling the compressor .
Try tapping on the thermostat , and see if refrig starts . Not a slight tap (except at first) but not a heavy tap either .
Excellent organization of your question , with the complete model number . Most do not give the first 3 numbers , therfore , unable to help them .
Oct 21, 2009 | Kenmore 61042 Top Freezer Refrigerator
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
Kenmore Top Freezer Refrigerator Logo
100 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
