Question about ViewSonic Graphic VG2021m LCD Monitor
Out of Range HFreq 91 KHZ and V Freq 85 HZ How do I fix?
    Problem Solver:
  • 5 Answers
Lower your resolution step by step until it is in range.
Posted on May 27, 2011
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
D-sub out of range 53.6 kHz / 85 hz
the problem could be said to be with either your motherboard or your monitor. Your motherboard is giving out at signal faster than your monitor can handle. If order to fix this you will need to use the monitor you were using earlier and change the resolution to 800x600 (varies by operating system, in windows you can generally right click the desktop and click properties and change the resolution under the rightmost tab on the dialogue)
Then connect it to the monitor you are trying to use and use the recommended resolution.
Mar 05, 2011 | Computers & Internet
Do you have specs for cerwin vega 211 bought 1975 and how offen should you have to refoam them
FREQ.RESPONSE: 32 Hz - 20 kHz
POWERHANDLING: 5-100 WATTS RMS
SENSITIVITY: 98dB
CROSSOVERPOINTS: 2500 Hz.
IMPEDANCE: 4-8OHMS
LOWFREQ. 122W2 or L121 12" / 2" VOICE-COIL WOOFER
HIGHFREQ. UHF-91 or DT-8 5" DHORM (1" VC) (9284 or 2686 diaphragm)
VOLUMECONTROLS: HIGH
DIMENSIONS: 15.5x 15.5 x 26"
CIRCA MID70s
Refoaming is not something you need to do very often. Even every couple of decades seems excessive to me. If they show no deterioration or damage and sound ok you may not need to do it. But if you are an enthusiast, you may be able to hear an improvement, and also may wish to give a nice pair of speakers the attention they deserve. I don't expect you will need to do it again in quite a while. If you can. In another 35 years they may not sell the kits any more.
Feb 10, 2011 | Audio Players & Recorders
I Have flatron w1934s monitor .. from 1 week it displays a message 'out of range 68.5 khz / 85 hz' and i have to restart the computer to continue .. can u teel me how to fix this problem ?
most likely you are going to need to contact the manufacture and have it replaced if its only one week old it should be on warranty I believe it to be a problem with the monitor not the pc however if that were not to fix it then i would suggest replacing your video card or atleast reinstalling the video drivers
Sep 23, 2010 | HP Computers & Internet
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
When computer is booting up, the monitor goes out before it gets all the way up and says the Horizontal, and Vertical is out of range. The menu says that the freq. is now Hor. freq. 91.1 KHZ, and Vert....
Turn the monitor on without turning computer on. Use the OSD (On Screen Display to lower the refresh frequencies. On the monitor look for a Setup button. The arrows allow you to scroll through the options. Do not forget to save settings.
Hope it helps.
Sep 20, 2009 | Computers & Internet
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Dec 13, 2008 | LG Computers & Internet
ViewSonic Graphic VG2021m LCD Monitor Logo
220 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
