Question about SAMTRON 55V 15" CRT Monitor
Monitor fault sir, i got samsung 17' , its not working, i unpluged the vga chord i.e 15pin connector, and connected only the supply chord, the monitor on's and shows the colour, cpu also function, only thing when the vga is connected monitor does not function, let me know what is the possible faults, what is the remedy for this fault
Crt
Posted on Sep 02, 2008
Vertical controll is damaged
On smaller Proview monitor, model 468, there is not power cord.
On the Proview 468 and possibly the PL-456s and the PZ-456if you look at the end of the VGA chord that you connect to the back of the computer right in between the two screws is a power connector for a 12 volt power supply this is for the 468 I hope this helps with your dilemma on how it gets power. tjbraya@yahoo.com
Feb 11, 2012 | Relisys RLT1720 17" LCD Monitor
How to check Samsung 732N 17 inch Monitor Power supply module
Open the case, open the main power supply board out and check the dc volts on the pins of the connector to the VGA board the volts are written in the board
Nov 28, 2011 | Samsung 732N 17" Monitor
Will my 64mb GF2 support dvi and / or hdmi connection (I want to get a flat panel monitor)
Not directly......but no worries!
All hope is not lost with just the VGA out on your card!
First, every flat panel monitor I have ever seen has a VGA input, so your GeForce2 card will still work!
VGA is still the top analog signal standard for computers. I am writing this with my on-board NVIDEA GeForce, connected to a Viewsonic VA2226w flat panel monitor using VGA and set at a resolution of 1680X1050!
Almost forgot..... just ignore the "TV Out" on your card.... this is old school and will give you nowhere near the quality you will get from VGA.... it was meant as a "crowd pleaser" to allow people to connect to their old school big screen TV sets.
Get the flat panel display... you will find out that it will work just fine with your VGA connection.
Feb 19, 2011 | Nvidia GeForce2 MX400 Graphic Card
How to repair HP 1702 lcd monitor with broken VGA cable
u can cut 15pin vga socket and u can replace with new
Jan 22, 2011 | HP L1702 17" LCD Monitor
When I connect the moniter to the graphic card geforce 6200 it will not show a display at all. connection to the computer using the regular connection it shows
On both the Graphics card and the monitor, the blue connector is a 15 pin DSub VGA video and the white connector is a DVI video.
With the monitor it should default to the 15pin DSub video input.
If you want to use the DVI video input you need to configure the monitor to use the DVI video input. DVI to DVI give the best picture quality.
If you want to go from 15pin DSub to DVI you need a converter cable.
Try conviguring the monitor for a DVI video input.
Jan 30, 2010 | XFX GeForce 6200 Graphic Card
My SyncMaster 740n is stuck in power save mode. I have rebooted, unplugged power and vga chord...the thing was on and all of a sudden POOF it was black. The power light blinks every second or two.
zolio, Monitor most likely has "switch-mode-power-supply" problem!! click on blue highlighted "SyncMaster 740N" and read about similar BLACK SCREEN of DEATH failures and how to fix them!! Your monitor I suspect is no different than any other LCD with "cold-cathode-fluorescent-lamps" for backilghting that fail to light-up. You can even visit YOUTUBE for videos on fixing BSOD problems!! Also a ton of stuff here on FIXYA!!! Just read and follow some of the links!! you WILL find out about everything you DIDN'T know of HOW and WHY lcd monitors fail. And better still, LEARN how to do the repair work or contract out the work to a Technician or other monitor REFURBISHMENT depot. Have you tried SAMSUNG to do warranty work? If this response was of some help please rate on FIXYA . 12fixlouie
Nov 12, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
How to connect samsung pasma tv to pc?model number is PS42B450B1XUM
That does depend on the PC, but I'll assume it's a pretty standard PC.
You ideally need a Male 15Pin VGA cable to Male 15Pin VGA cable. (aka A normal Monitor Cable) The same as you probably have connected between your PC and Monitor.
Your TV has a 15Pin VGA Female socket on the back, this cable plugs into here.
For Sound the TV has what looks like a headphone socket next to the VGA Plug. You need to use a Stereo Jack Plug to Stereo Jack Plug Cable. 3.5mm. This goes from your PC's Audio Line Out (rear of the PC) to the Plug on the rear of the TV. It is usually marked Aux In or PC Sound.
Enjoy, The PC will look great on the Tv.
Sep 06, 2009 | Samsung Televison & Video
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Samsung 710V - controller box
your monitor's video section is fault change video amp. ic or check cpu cable(vga cable).
Oct 20, 2007 | Samsung 710V 17" LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
65 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
