Question about Kenmore Washing Machines
Washing machine will not start the wash cycle after filling with water. I have tried normal, delicate, and heavy duty cycles.
Mine is a VOLTAS Fully Automatic Washing Machine - Model Washmaster HIT Top Loading Machine. The motor makes a humming noise only but does not rotate. What could be the reason? It was working fine.
Posted on Jul 04, 2011
    Problem Solver:
  • 17 Answers
Not sure what model you are referring to, but in general, it sounds like a problem with the timer switch or if it's all electronic, then it will be in the control board.
If I had the model number I could be of more assistance.
Posted on May 27, 2011
Kenmore elite he3 front-loading washing machine (110.4282) will not run on the normal cycle. It will do heavy duty or delicate, but will not let me change water temperatures.
Please make sure that you are getting both hot and cold into machine from supply lines. Thank you and please leave feed back!
Jul 10, 2016 | Kenmore Washing Machines
Machine will wash on hot only will not on cold or will not fill with cold at all
This is an indication that the solenoid on the cold water valve is bad. Or the cold water valve is plugged. If you can get to the valves, use a meter to check the solenoid OR the power to the solenoid. That will tell you if it is bad. If you dont have a meter, switch the wires from one solenoid to the other and see if it fills
Feb 01, 2013 | Whirlpool Clothes Washer Heavy Duty...
Hoover 700LB Stops at the wash during the wash cycle keeps clicking then starts again at the spin cycle
It sounds like the timer is bad. Try another cycle like delicate, or normal, or heavy duty. If everything works on another cycle then it is probably your timer. If it doesn't work and you have the same problem, then it is probably an expensive fix. Best of luck
Mar 21, 2010 | Hoover HTC243 Top Load Washer
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
