Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
  • Anonymous Mar 28, 2014
    It fills, washes, drains, fills, washes, drains, fills washes, drains for hours
    Problem Solver:
  • 17 Answers
The motor may be siezed, or there may be something in the impeller that is keeping the motor from turning.
The only way to know for sure is to remove the motor unit and visually inspect it. If you cannot manually move the impeller or if it is very difficult to turn, then you will need to replace the motor unit assembly.
Its costly $155.36 plus shipping at www.searspartsdirect.com But if the motor is bad then the motor is bad.
Just curious, how old is the dishwasher?
Posted on May 27, 2011
    Sergeant:
  • 231 Answers
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
http://www.youtube.com/watch?v=vNQvDqzMZV4
Kenmore Elite frontloader flashes f problem seems to be intermittent
it would first try cleaning out all the filters inside the dishwasher then run it again. And if it still sounds like the wash motor is grinding or humming badly then you may have a seizing wash motor. And if it doesn't drain well either you may have food caught in the drain motor as well. And cleaning it out if you find a lot of debris may help. But if after cleaning that too and still doing the same thing you will need to replace the drain moto
Jan 21, 2014 | Computers & Internet
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains...
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
May 27, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
GE Dishwasher won't fill (Tested valve and switches)
check thermostat it maybe overheat and gives a false signal that water is warm,it is on bottom.
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Jun 18, 2017 | Kenmore 24 in. 17052 / 17054 / 17059...
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
381 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
