Question about Sport & Outdoor - Others
I have a ES 1000 watt yamaha generator that will only start if I put gas in the cylinder & It runs until the gas is burned off. I have gas to the carburator and have cleaned jets & ports etc, I have sufficient spark...any suggestions ? Thx in advance.
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
  • 8 Answers
SOURCE: 98 YAMAHA WARRIOR 350 WONT START
have your carb. rebuilt and make sure there is not anything in the intake tube between the carb and the engine.
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: my 2002 yamaha blaster will not start.
Check that you are actually getting spark to the plug first. If you're getting spark, check your timing. I would say these would be the easiest 2 areas to start with. If both of these are good, it could be anything in your wiring, or your CDI box. Good luck!
Posted on Jul 08, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
Does the yamaha EF1000is inverter generator 1kva
it seems to be the standard that the rating or model ??1000 or ??1500 or ??2500 or ??5000 or??5500 or ??6500 is the kv rating of the gen-set regardless of straight or inverter
so if yours is EF1000 it will be 1000 watts or 1 kv
remember that most electric drills are 1000 watt units so a unit this small is mostly good for lights, charging batteries, small compressors for tyres
Jul 04, 2015 | Yamaha Electrical Supplies
How do you stop generator from stalling under load
As you have not provided me with the information I requested I'm going to have to take a few guesses here Bob. You could be overloading the generator. You can't run a 10,000 BTU air conditioner off of a 1000 watt generator. You need to look at your load, (what you are trying to power), and determine how much power it needs. Almost everything has a tag somewhere on the device. Most don't give watt requirements. But they do tell you, how many amps the device pulls, as well as the voltage the device needs. So you need to do some math here. Volts X Amps = Watts. So if we have a 120 volt device, that pulls 15 amps, we need 1800 watts to power it. But it gets a little more tricky than that. Motors are often rated at what they pull while they are running! But it can take two or three times more power to get them started. Example... A motor rated at 10 amps, using 120 volts will be 120 X 10 = 1200 watts. But it could take 2400-3600 watts to get it running. So in theory a 3000 watt generator may die before it can start that load. Heating elements are also power hungry! Let's say you have a small 800 watt generator, and your just trying to run a simple coffee pot! Well the heating element in a typical coffee pot pulls 1000-1500 watts. A hair dryer or microwave oven rated at 1000 watts, is the power they produce, not the power they consume! So a 1000 watt microwave may pull 1600 watts of power to run. Most non US generators are highly over rated as well. I certainly would not trust a Harbor Freight 3000 watt generator to actually put out 3000 watts of power. Not that they are bad units, I would expect their numbers to be under PERFECT conditions. Temperature, humidity and altitude also play a part! Your 3000 watt generator is going to put out more power at 50 degrees, at sea level, than it is at 7000 ft in the mountains at 100 degrees. So my "guess" Bob, is that your just asking more from the generator than it can produce. Picking out a generator is not as easy as it looks. "Hey that one is $1000 and this one is $300! They both make power! What's the difference". The difference is what do you need to run! "Heck I'll just get that 50,000 watt unit"! Yeah you can do that too, but you will never use that much power, and you will burn way more fuel than you need to. My other "guess" is that you have a governor issue on the engine. As load increases the gov will throw more throttle to the motor. My generator has an option to run full speed or on the gov. So it will idle and burn less fuel while I am hammering in a nail, then go to full power when I trigger a saw connected to it. Lot's of factors involved here Bob.
May 30, 2014 | Generac Electrical Supplies
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
I am interested in a generator that can light a 3-bedroom hse and a chauff cutter
Your cutter machine may use more power than your whole house depending on the size of motor. A one horsepower motor 115v will use about 3000 watts to start and about 1000watts to run. To estimate how much power you need, add up all the watts that you will use at home and add to that estimated wattage of the cutter motor (motor will use 3x rated wattage to start plus loss of power thru the extension cord). Buy a generator that will give you needed power and still have a 25 percent reserve. If you need 2000 watts on a continued basis, the 2800 watt may be good, however I would be more comfortable with a 3500 watt if the price was right because of the cutter machine. I would consider converting the cutter to gas power and buy a smaller generator to save on gas since you will be most likely running the generator far longer to power the house. Good luck
Aug 11, 2011 | Yamaha 2500 Watt Industrial Inverter...
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Fg2000tc tried a 1000 watt jack hammer but overload alarm came on what to do
Your gen. is a 2000 wt max 1000wt running out put. Means it will start your jackhammer but will not maintain the wattage to run it long. You are using the max it has to put out. So let me try to explain - 2000 watt max output works like this - We will use a fan as an example. A fan sitting still and not turning takes more amperage/watts to start. that is called lock rotor amps. So lets say the fan is a 1000w to run. 2000w start the fan turning then it takes 1000w to keep it turning. Your gen. can start the fan but not keep it running it is using all it has to put out, now if that fan only uses say 750 w running watts you have some head room to keep it running with out things getting hot. Hope this is clear as mud.
Jun 06, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Had to tickle the throttle on my yamaha 3500 watt
You should have automatic or manual choke control. Try to find it and open it during start. After that you can close it if stable work is achieved.
May 30, 2010 | Yamaha 4500 Watt Electric Start Generator...
I have a 6500 es that keeps blowing the 15 amp fuses. It will sometimes run 1 hour or maybe even 2, but then it blows the fuses. What could be the problem.
What are you pluging into the generator??? If the the item/s are drawing more amps or watts, than the 6500 will handel, EX: 6500+or++ or if you add something while it is running, ka pow! Please let me know specifically what you have pluged into it, the fuse only blows if you are overloading it! Check the amp or watt draw of what you are pluging into it to see if the generator can handle it. If you overload the generator enought times you can burn the windings and than it gets costly. Talk to your local shop about what it can handle.
Jul 18, 2009 | Honda Electrical Supplies
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Sport & Outdoor - Others Logo
73 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
