Question about Diamondback Sorrento 26" Mountain Bike
I am borrowing a diamondback from a friend and it has been a LONG while since I have done any bike riding. I am not even sure how the gear shifting mechanism really works. I was pushing the levers randomly yesterday trying to figure it out.....any thoughts?
    Brigadier General:
  • 8,546 Answers
Each control is binary - harder to shift in one direction, easier in the other.
Google "how to shift a bicycle" for videos
Posted on May 28, 2011
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
Diamondback tess 24 has clicking in gears and is hard to shift
sounds like the derailleur cable is stretched out and needs to be adjust. search here or google on how to adjust a derailleur, or take to your local bike shop, it's a cheap repair.
Apr 12, 2014 | Diamondback Girls Tess 24 Mountain Bike...
Where should I set the gear and the friction when casually riding my Serene Comfort on level ground?
The above doesn't answer the question as I have recently purchased the same bike. I was wondering the same thing. Should I be at + or - (which gear wheel should it be on 1, 2 or 3?)
Jun 24, 2011 | Diamondback Serene Citi Classic Women's...
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
I was just given a diamondback SHERWOOD bike. I don't know how to use the gears -- what's the right shifting pattern for hills
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chain line is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you
Apr 01, 2011 | Diamondback Cycling
I have a diamondback serene women's bike, can't shift into 3rd gear. grip turns extremely hard and then if I get the shifter to 3rd, the gears on the bike just click. have to ride it really hard and...
Many possibilities, including derailleur outer limit not correctly adjusted, derailleur not mounted correctly, tight bend or friction in cable. Talk to the store manager/owner about correcting your complaints or find another shop or a bike co-op. If the bike is a major brand from a bike shop (Trek, Giant, Cannondale, etc.) try going to their website, look for Customer Service/Support and enter a complaint.
May 23, 2017 | Diamondback Serene Citi Classic Women's...
How do I operate the gear shifters on a diamondback sorrento?
Here's a great article on that subject. The article covers virtually any multi-speed bike, including yours. One thing the article leaves out is that in order to shift, the chain must be moving, which means that you must be pedaling. But it works best if you are pedaling very lightly.
http://bicycleuniverse.info/eqp/gears.html
Jun 30, 2010 | Diamondback Sorrento 26" Mountain Bike
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Diamondback Sorrento 26" Mountain Bike Logo
141 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
