Question about Dryers
Need to get ink out of my gas dryer but everything it says to use online is flamable. what can i use?
  • Mark T
    Mark T May 27, 2011
    How much ink and where is the ink?
    Problem Solver:
  • 17 Answers
Most things that can remove ink can cause damage to the glaze finish on the dryer tub. Go ahead and use a specialty product that will remove the ink, but use it sparingly and dab it onto a rag.
Once the ink has been removed to your satisfaction, take a moderately damp cloth with a mild detergent (dish soap like dawn or ajax will work.) Wash the area where the ink remover was in contact with the tub. (you may want to rotate the tub manually so the spot is at the bottom of the machine)
After washing the area, then dry it with a towel.
If you still smell the odor from the ink remover then, allow the dryer door to be open for about an hour or so to allow any combustable vapors that may still remain to air out before using the dryer again. Or you can run the dryer without heat in "Air Dry" for about 30 min until you cannot smell the vapors in the exhaust anymore.
Hope this helps
Posted on May 27, 2011
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Maytag Neptune dryer model # MDE2400AW, is running but has not heat. I need instructions on how to take it apart and fix it. Also where to find parts from. Thanks,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 12, 2010 | Maytag MDE2400A Electric Dryer
No heat
Check the vent hose from the lint screen all the way to the outside flapper many calls I get of no heat on dryers is from people putting stockings over the vent in the winter and then back to the vent in the summer but what happens is that they don't clean it every week or more and it now builds up in the dryer blower and when hooked back up the the vent it blows a big glob of it and it then blockes the vent, this is also very dangerous because dryer lint is very flamable. Be sure to disconect power before cleaning the hose and blower in the dryer.
Jan 28, 2010 | LG DLG3788W Gas Dryer
Codes 440 446 evaporative.. Good idea to warm
You can't check a gas cap by seeming. An emmisions staition will check it for you. You don't want to do that hair dryer warming. Flamable and rubber hardening is heat to gas vapors.
Oct 20, 2009 | 2000 Toyota Corolla
Ink stains vin my frontload gas dryer
Spray hairspray onto cotton and wipe off. Then wipe out the hairspray with a clean damp cloth before drying again.
Sep 24, 2009 | Whirlpool Dryers
INK PEN IN DRYER INK MARKS ALL IN DRYER HOW DO REMOVE INK
use a cotton ball with a small amount of Eucalyptus oil and wipe clean.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Sep 12, 2009 | Whirlpool GEW9250P Electric Dryer
The dryer will not start
You gonna have to lube the rollers and wheels and check the motor. Must be about to go. You can oil the motor but you will need to makes some holes. use zoomspout oil. High temp resistant non flamable and $2 at any ace hardware store.
Mar 27, 2009 | Dryers
Dryers Logo
Top Dryers Experts
