Question about Eva-Dry E333 Dehumidifier
I bought the eva dry e-333 on 4/30/11. I placed it near my toilet tank in the bathroom. Everything was working fine until two or three days ago. I noticed that the tank had water condensation and the eva dry was still indicating blue, which means it still wasn't time to recharge. Please help me as I am noticing that my toilet tank is building water as before. Thanks.
  • 127 Answers
You are trying to fix the symptoms rather than the problem. The problem is the water going into the tank is colder than the air in the bathroom, which cause condinsation on the tank. If you can, take the chill out of the water. By exposing the pipes, which may cause the pipes to sweat. Or cool the room air. Is the bathroom vented so that the warm moist air is carried outside? There are liners that go in the tank that work well. If you use a liner make sure you will still have enough water to flush with, as they will take up some of the water volume.
Posted on May 27, 2011
Can it be used in toilet ? The walls are damp due to basement
It can be used in a bathroom in a safe place. It might taut of the bowel and drain traps but should not take any water out of the tank an air conditioner is a big humidifier so if you have an A/C you already have some moister being taken out. And a heating unit takes even more out then the A/C so I would say no problem.
Aug 28, 2014 | DeLonghi Dehumidifiers
Water is leaking out .At first i thought the tank had developed a leak but no, somehow the water is not getting into the tank .Is there something i need to clean? It was working great until this started...
More than likely, the tubing the drains the water to the water collection bucket is clogged. To solve this problem, turn the unit OFF and unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helped you to solve the problem and thanks for choosing FixYa.
Sep 20, 2011 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
Didn't LG produce some bad Humidifiers several years ago and have a recall on not working units? I recall reading this in Consumers Reports. I bought one back then and it has not produced a drop of...
If has not produced a drop of water for several years, then it's not working properly. But, this may be a case of setting the humidity level to high. In other words, if you set it at 70% or Maximum, that's the humidity level that it will maintain, not remove. To remove humidity, the level must be set low (35% or Minimum).
To test the unit, based on what I just said, place it in the bathroom, set the level as low as possible and turn the shower on medium hot. Do Not turn the bathroom exhaust fan ON. As you leave, close the bathroom door. Return in 15 minutes, turn the shower OFF and check the bucket water collected. If there's any water in it, it's working fine. It was probably a case of the humidity level being set to high.
Hope this helped you. Please let me know. Thanks.
May 16, 2011 | LG DH305 Dehumidifier
My small inexpensive dehumidifier stopped working, its trying to start but just can't. I have never cleaned it, lost the instructions. 1 yr. old it worked great all this time . Thanks Johnny L. PS its...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 17, 2010 | Eva-Dry EDV1100 Petite Mini-Dehumidifier...
My dehumitifer freezes up shortly afer being turned on. Why?
This can happen if the Temperature in your room is too low. You can work around it and place a 40 watt bulb near the the inlet of the humidifier to warm up the air a bit. Also if the humidity level in your room is already too low this can cause your dehumidifier to freeze up.
Jun 11, 2010 | Eva-Dry EDV300 Dehumidifier
Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
Kenmore dehumidifier that does not collect water
if the air is cooler, it is drying. the air might not bee that humid, especially if you have an air conditioner.
Jul 29, 2009 | Eva-Dry EDV300 Dehumidifier
No drying!
I just got the same model via mail order, and it isn't drying either. I'm going to give it another day before I send it back and buy some other junk product locally that is easier to return.
Mar 17, 2007 | Danby DDR583R Dehumidifier
Everything works, but does not collect water
I have the same dehumidifer - make and model. I bought it less than a year ago. It too runs fine, but now collects no water. Did you ever discover how to fix the problem?
Sep 04, 2006 | Goldstar DH504EL Dehumidifier
Eva-Dry E333 Dehumidifier Logo
129 people viewed this question
Top Eva-Dry Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you an Eva-Dry Dehumidifier Expert? Answer questions, earn points and help others
