Question about Hitachi Televison & Video
I have a Hitachi L32HP04UA TV ,do have the best picture settings for this set. I just cant get it to look natural.
I have a hitach
L32HP04UA it was working fine till one day i switched it on and it won't start ,the green light come on for a few seconds then it witched it self off again before the screen came ona
Posted on Jun 11, 2012
First of all, press the presets button on the remote, and cycle through the settings by pressing again and again. To adjust these settings, press MENU on the remote and go down to TVSETUP. Using the arrow up/down, left/right keys, you can adjust the colour, brightness etc for each mode selected and when finished, select STORE.
Posted on May 30, 2011
I have hitachi pj-tx100 projector and the picture is upside down. How do i fix it?
Best to check the Mirror setup on page 26 of the manual. Download from
http://www.projectorcentral.com/pdf/projector_manual_2505.pdf
The setting might be in Invert for H&V.
Aug 21, 2014 | Hitachi Televison & Video
Tiny "guide-size" screen remains when I'm out of guide
HI,
I'll let you know if there is a mnual available online for your model.So that you can find out some troubleshooting steps.
Apr 16, 2008 | Philips 42PFL5332D 42 in. LCD Television
I have a Hitachi 55vs69 I replaced the bulb and it went out in 6mo. Is there something else that might be wrong.
The number of hours, coupled with the TV viewing conditions, is a more accurate way of interpreting the proper bulb life expectations.
For example; a TV like yours that is set to watch the winter Olympics for two hours per day will not last as long as one that is set to watch something like Ghost Hunters for two hours per day. The reason is the output demand on the bulb...brighter pictures will burn it out faster.
The best way to get the most life out of any bulb, or any TV as a whole, is to properly calibrate your TV. Getting the correct picture levels does more for the TV than simply improve the picture quality.
I recommend a calibration tool you can find on DVD called Avia. Or you could simply use some of the calibration images provided with some THX certified movies. These are by far not the best available choices, but are the simplest and much better than the ***** eye. The discs are intended for calibrating the output of video from dvd playback, but you still could use the same calibration settings for all of your outputs if you wish.
Aug 26, 2011 | Hitachi 55VS69 55" Projection HDTV
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
Hitachi model 43uwx10b comes but no sound or
sounds like one of the transistors attached to a heat sink shorted out.
you will need to test each one with the tv unplugged.
set the digital meter on diode.
it`s not easy to explain the rest, sorry.
Sep 08, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Vertical collapse of picture then no picture
You most likely don't need to replace a board. You should solder the bottom of the vertical output, it probably has bad connections. If you don't know where the vertical output is, give me a model number and i will give you a location, or take a picture of the deflection board and i will circle it.
Tim Nolan
Sep 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Blurred pic on tv
you can take the back off find your flyback (the big part with a red or pink wire going to the picture tube) and adjust the small pot or potentiometer closest to the top while the set is on in front of a mirror and try adusting the focus control.
if cant get nothing but blur replace the fly or focus assembly if not built in the fly. I would change both.
Jan 26, 2008 | Hitachi C21RF39 21" TV
Hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Apr 08, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
225 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
