Question about Dell P1500 Laser Printer
Feeding almost whole paper tray causeing bad binding problems
  • 159 Answers
Try cleaning the paper rollers. if they are too worn out they will need to be replaced.
Posted on May 27, 2011
How to remove this Code Sc-46-25
1. Failure of A/D conversion board (ADB).
Check the connections between the ADB and the ICB and reseat. If the problem persists, replace the CCD (p/n 55VA-6110). Under the big glass. OR
2. A bind in any paper tray lift mechanism, not allowing the tray to raise. Repair the binding of the paper lift up plate in the offending tray. To isolate the tray causing the problem, power the machine ON with one paper tray withdrawn at a time until the offending tray is found.
Notes :
a. The bind with the paper lift up plate may be cause by the rear and side guides being too tight against the paper.
b. This problem may have been caused by the machine being moved with paper in the tray.
c. A SC18-xx code may also appear at power up.
d. Inspect that paper was properly loaded by the end user.
Dec 03, 2015 | Konica Minolta DI850 Developer Starter...
How do I fix...error 13.B2.D2 on hp laserjet 500 m525 mfp
Make sure that the paper guides in the tray are set properly. People have a tendency to set them too tight and it binds the paper. Also inspect the condition of the pickup roller. Pull out the tray and look at the top edge of the tray cavity. Look for the grey or black roller in the front center. It should have ridges on it and be clean. Rollers that are dirty or smooth will cause misfeeding which generates this error. Make sure you are not loading too much paper in the tray. There are guides on the side tray guides that the paper must be under. I have also run into reams of paper that were glued on one end due to faulty packaging which causes the printer to not be able to feed a single sheet. Fan the paper in the tray to make sure no edges are binding.
Aug 07, 2015 | HP Office Equipment & Supplies
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Thanks.
Oct 06, 2010 | Computers & Internet
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Xerox 6100 laser - paper jams if paper tray low on paper
There could be two things. First, be sure the paper tray is not binding. The metal plate in the middle should spring up easily. The friction pad should be firmly attached to the tray, but not extending over the metal portion. The second thing would be to clean or replace the feed rollers. They are inside the machine above where the tray would sit. Since the tray feeds when full, I don't think you have a clutch problem. Let me know how it goes.
Jun 10, 2008 | Xerox 6100/DN Laser Printer
Printer Printing Crooked!
try printing from the multi purpose tray...do you get the same problem...if not you can narrow the problem down to the paper tray area...try changing main pickup roller and separation pad. If problem is present printing from either tray then the next place I would go is to the registration assembly (flapped unit that resides under the toner cartridge). The job of the part is to line the paper up before it feeds further in to the printing process. You could also do whats called a 1/2 test...put paper in the mp tray, do a print and when there is only about 2-3 inches of the paper sticking out the mp tray open the toner lid...lift out the toner cartridge and see if paper is skewed before entering the fuser. It really does sound like the registration assembly.
Inkworks
Apr 24, 2008 | HP LaserJet 2100 Printer
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Dell P1500 Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
