Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP600 paper jam
I have a Canon MP6oo it is 5 months old . it is telling me there is a paper jam, but there isnt, i turn it off and on again and it takes the paper then says the same again can you help me? I have the same problem.  I've tried all recommendations from Canon's owner's manual, etc., and nothing clears it.  Anyone with some advice on this?  There's no paper and I've been advised that it could be a stuck sensor.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
That is correct..this puppy still under warranty?
Posted on Aug 19, 2008
Hello, my name is sugeng arifai,,, i'm from indonesia...sorry,but i'm cannot speeking english.... printer canon mp 198 Error 6000? help me please mr.?....
Hi, this error code means that either one of the trouble has occurred:
Either there is a "Paper jam" in or "General malfunction" in the printer..
there might be some pieces of paper or dust in between the rollers. please carefully examine roller area and take a good look into rollers.
And than Try to reset the printer to erase memory code errors.
1. Press Resume button and hold it for 1 - 2 minutes
2. Open the cover
3. Remove the cartridge and then put it back again.
4. Close The Cover
5. Turn Off the printer wait and then Turn it On again
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Mp600 paper ouput slot error will not reset
canon printer is telling me that i have paper jammed in paper out slot when ther is no paper in it can it be reset? or is it not fixerable by my self.
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam in canon MP600 Printer
If you cannot see the paper jam, perhaps it is inside the machine:
1) Open the rear cover and inspect the area for any bits of paper that might impede the paper path
2) On the front of the machine, pull out the cassette (paper tray) and inspect the cassette area for any paper jammed inside.
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
Have you tried turning the printer off and back on again, along with the pc?
Oct 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Pink tinge to colored photos
Canon has a number of things you can check in their knowledgebase. Go here. Type "pink tint" in the search box and click Search. If you select the first item "tinted printing" you will get at least 21 things you can try (only 10 show up per screen).
Apr 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I recently had the same problem and was very bummed, because I like the printer, having received it as part of an Apple bundle promotion.
The problem I was having is that I had paper in the rear (auto sheet feeder) area and when I'd try to print, all I heard was clicking and then I'd get a message that there was no paper installed.
Here's what to do.
On the panel, on the left side, there's a button called "Feed Switch."
You'll notice that there's a graphic of the printer to the left of the button with 2 lights. Push the Feed Switch button to toggle the light from the front tray (cassette) to the rear tray (auto sheet feeder)... and when the light is on the rear try (vs. the front tray) you're all set.
This will fix the problem.
Jan 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600 Paper Jam
I just had the same problem, tried everything and resigned myself to buying a new one. I was about to throw the thing when I saw the Card backing of an A4 Pad. I thought I have nothing to lose so forced this through the machine and Bingo. It cured it.
Jan 17, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
166 people viewed this question
old marine
old marine
