My mitsubishi WD62528 projector tv is not powering on. when the tv is tuned on the timer light blinks for sometime before it becomes steady while the lamp light and status light is off. i sent a message last year and i got a reply that my lamp was faulty, i replaced the lamp yesterday and the tv powered on after resetting it like five times. The tv was on for five minutes and it powered off and has not powered on since 7pm yesterday till now. i live in Lagos, Nigeria
    Genius:
  • 1,156 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, and do take care in handling the set
Posted on May 27, 2011
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
There was a power outage in my zipcode; and when the power came back on, the timer light on my tv was blinking and will not stop. This is not allowing me to turn on my tv.
Thats a very common problem caused by bad DM capacitors. The caps discharge during the power loss and then cannot recharge when the power is restored whcih causes the steady blinking green led. You can get the DM repair kit for your model at www.tvrepairworld.com which does include the upgraded caps and the CD with instructions.
May 06, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Fan in ventilation didn't work and power lamp steady red,lamp red and Temp lamp binking red
Very likely the airvent is block or the timer for the airvent cleaning is max. See manual how to clean air vent filter and reset the timer after cleaning it
Aug 08, 2010 | Mitsubishi LVP-X390 Multimedia Projector
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
Aug 22, 2009 | Mitsubishi WD-60735 Projection Television
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Oct 28, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
