Question about Whirlpool MH7130XE Microwave Oven
I am trying to locate the fuses in my whirlpool mh7130xeq-1 ... I know where the mainline fuse is and have replaced it, but it seems like the until gets awfully hot when running the microwave, and I don't the the fan is running.... is there a separate fuse for the fan?
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
I am having a hard time grasping the problem here. I have to assume that the microwave fan is the problem and not the blower fan. No worries.. ALL of your questions can be answered by this manual if you understand Technician procedures:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/0/52015b2c875fae4d85256a8c0062547e/$FILE/4322167.pdf
The cooling fan should be running any time the turntable is moving.
Fan motor is item 1 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260365&diagram_id=28278660#d28278660
This is the fan motor: http://www.appliancepartspros.com/part_details.aspx?part_id=3034166
It can be lubricated with a parafin based oil (Zoom Spout turbine oil) of Union 76 turbine oil. It is best to remove the mounting screws for the motor bearings and then clean the motor shaft & bearing before lubrication. Do this on both sides of the motor. Most of them can be revived with proper cleaning and lubrication.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
Whirlpool gold YGH5184XPS-0 fuse location, I believe i blew a fuse and cant find the location, the thing worked fine and then i shut the door and lost all power, either the door latch is broken or the...
Mike - Unplug the unit and unscrew about 4 screws on the top and then the side panel and the fuse will be in that location.
Note: If the fuse looks brown, it's definetly blown, you can get the same fuse at your local Radio Shack for about $0.97. hope this helps
Aug 14, 2012 | Whirlpool Microwave Ovens
Model gh7155xhs how to find and replace fuse
Hello SHahidbell,
I understand that you need to replace the fuse in you microwave. I have located the fuse for you from partselect.com its cost is $12.27 here is a link to the part http://www.partselect.com/MultiModels.aspx?ModelNum=gh7155xhs&SearchTerm=fuse&RefineSearch=0
1. Unplug the unit
2. Remove the outercasing
3. Locate the fuse holder, this unit only has one
4. Use a pair of pliers to remove the fuse gently not to crack it
5. Install the new fuse
6. Install the outer casing
7. Plug in and try
You do not want to try the unit with the outercasing off. Microwaves give off radiation the outershell helps to reduce this radiation.
Thank you for choosing FixYa.com
Justin
Mar 10, 2011 | Whirlpool GH7155XHS Microwave Oven
Need mounting hardware for MH7130XEQ Where to get
You can find helpful exploded view diagrams and order parts here.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 23, 2009 | Whirlpool MH7140XF Microwave Oven
No Cooktop Lamps
9a1ba72.jpg You can solder a wire on here to bridge the broken trace. 1 min fix!
Jan 31, 2009 | Whirlpool MH1140XMS Microwave Oven
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Nothing working - just quit. Power source ok.
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Dec 29, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool Miccrowave (GH7145XFQ-1) went dead...
Does the display light up?
Are you sure it is getting power?
Check that and get back to us cause the next step is going inside
Jan 01, 2008 | Whirlpool GH7145XF Microwave Oven
Microwave doesn?t turn on
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problerm on the control circuit board. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 15, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
202 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
