Hi i have an advent 9515 laptop which when u press the power button the power light comes on but nothing else. Ive tried with the mains adapter connected
    Problem Solver:
  • 8 Answers
Most cases this is a sign that you CPU (main processor) has failed. this could be due to over heating. This will need to be repaired at a local computer shop.
Posted on May 27, 2011
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
Samsung laptop problems
try cold reset by removing the battery including power adapter then press power button for approx. 20 secs. then plug your power adapter then press power button again. press the numlock/ capslock button if there is response showing that your motherboard isnt dead yet. please check also when fan is running momentarily then suddenly stops then post another question here.
Dec 02, 2013 | Computers & Internet
Problems advent 5302
There is a problem in adapter. You should change it or buy new one.
Aug 04, 2013 | Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
I press my power button on and nothing comes on the screen. My screen is black as if it wasn't on. Please help me I have a Dell VOSTRO 1000
does a light come on when you press the power button? Remove the battery then just use the power adapter.Then check the cables of your power adapter if it is connected properly. Try unplugging and replugging the cable at the back of your laptop. Make sure that on the the power adapter ( the small rectangular boxlike) has a green light. Then try pressing the power button again.
Sep 22, 2010 | Computers & Internet
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
Hi ive got a dell studio laptop the laptop powers up but nothing comes on the screen. The screen is less than 12 months old
HI there.
Try this things first so that you can check if it is really the screen that's causing the problem,
While the computer is off, press D+POWER button and hold it for 5 secs, different colors should come up,
Make sure the computer turns on. You will know that if the power button lights up. Try to lug in an external monitor and see if display will come up,
If the display comes up, and the d+power did not display anything, might want to call technical support so you can get the screen replaced,
Have a good day!
May 27, 2010 | Dell Studio 17 Laptop
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
LAPTOP WONT TURN ON OR DO ANYTHING
Remove all the cables etc inc the power lead
Remove the battery
Hold the power button down for 20 seconds
Replace battery & Re-start. If you are as lucky as me it will be 'Hey-Presto' and lots of happiness.
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
