Question about Hasbro Perfection Game Nib
The board is stuck in the down position, and the timer no longer works. Is there any way to fix it?
Anyone know why
If the machine has a mechanical control, the timer is stuck in a certain position. Whatever cycle it is stuck on will continue to run until the timer is advanced to the next setting. If you have an electronic board controlling things then that board is defective and needs to be replaced.
U might try unplugging unit to see if that affects the electronics. If manual timer, unplug unit and move the cam yourself to the next position.
Aug 06, 2015 | Maytag Washing Machines
Woods 59730 6 plug outdoor timer. Hour arrow is stuck and rotates with the outer dial. How can I fix it. Thanks.
Spray WD40?
If the timer still works, then the loose part should not be a problem.
The time-now arrow points at about the 1:30 position.
You can rotate dial until current time lines up with approximately 1:30 position.
http://waterheatertimer.org/images/GE15107-004-8.jpg
Gene
Water Heater Timers Save Money
Nov 29, 2014 | Woods Hardware & Accessories
Our great lakes spa seems to circulate non stop
Could be a bad timer that will no longer rotate to the "off" dog.
Or a stuck relay in the closed position for the pump.
either replace the relay or the board if you don't have individual relays.
Naturally, check for proper operation of the relay 1st, before replacing arbitrarily. But you have a direction to go into now.
Sep 12, 2014 | Great Lakes Spas Pool & Spa
I have a Maytag Neptune model MDG5500AWW gas dryer that won't shut off. Here is the scenario:The dryer runs continuously and dries the laundry but will only stop when you open the door or unplug it from...
On the face of it it sounds like the timer motor is not going and has stuck in the on position, but I would seek further advice. Someone competent and qualified should check whether the timer motor is getting any voltage and is working
May 13, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Frigidare dishwasher ..dead!
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 68690bea-e43a-408a-beaf-ff3b0809599a.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
Timer does not work and no rotation
HI, this is a simple fix here, simply replace the affected timer/control module. this replacement will fix the issues you have experienced.
The mechanism incorporated in the timer housing is damaged.
May 31, 2009 | Maytag Dryers
Camera stuck in open position.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 09, 2008 | Fuji FinePix F610 Digital Camera
Hasbro Perfection Game Nib Logo
37 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
