Question about Dishwashers
Outlet valve not letting enough water to fill up.
    Sergeant:
  • 231 Answers
Sounds like you will have to replace the fill valve.
Part number can be researched on the Internet by make and model number - can get the part from usually any appliance repair shop depending on the make.
To remove - shut off water - unscrew the kick panel and you will see a valve with a hose coming from a water source (usually blue or yellow or whiteish) - need screwdriver (for the screw holding it in place), pliers and towels to do the job.
Good luck
Posted on May 27, 2011
3 Suggested Answers
  • 4349 Answers
SOURCE: Water doesn't fill after 50-60 secs of valve
Float valve is not used in normal cycle, it is a failsafe method. Energy conservation issues dictated less water during washing.
Posted on Nov 01, 2009
heatman101
  • 43501 Answers
SOURCE: not filling enough,already replaced 120v
Did you check that you have a good water supply to the water valve....there may be a restriction upstream...
Also... is there 120v for sure at the valve? and how long is the voltage supplied to the valve... the control/circuit board may be bad...
Also check the float that tells the valve to shut off... it could be full of old food particles and be giving a false reading of the water level...
These are a few of the things that I would check next...
heatman101
Posted on Oct 27, 2010
Water still running when machine is off, what to check for
Here is what you can do to determine what part you will need to replace. Turn the washer on and let it fill with water on any wash cycle. While it is filling with water unplug the washer (power cord to the outlet). If water continues to enter the washing machine it means that the washer inlet valve will need to be replaced. If the water stops filling when the washer is unplugged then you will need to replace the timer or control board which powers the valve.
Oct 23, 2016 | Washing Machines
Water drains after filling with lid open
is your outlet pipe tall enough to prevent siphoning .
Apr 01, 2016 | Whirlpool Ultimate Care II LSQ9549L Top...
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Can you use a draper submersible pump for a garden irrigation system to use with several sprinklers, does it provide enough water pressure on the outlet?
Here's how to tell.
Connect a tee to the outlet of the pump.
Install a pressure gauge in the tee.
Install a valve after the gauge.
Open the valve and start the pump.
Once water flows, close the valve slowly until you get 50 psi on the gauge.
Have a 5 gallon bucket nearby and measure how long it takes to fill the bucket at 50 psi.
If it fills the bucket in 30 seconds, you can attach heads to the pump that combined consume 10 gallons per minute.
Let me know how you do.
Gary
May 29, 2011 | Garden
I have a six month old Bosch dish washer and 8/10 times the powder is not disolving?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Evidently the detergent cup is opening? Here are some of the possible causes; 1. Low on water (fill the machine, let it start and see if the unit has enough water). Sometimes the screen on the fill valve get partially clogged and slows the flow and when the timer engages and therefore enough water was not installed. 2. Defective fill valve (partially sticking valve sometimes will not let a unit get the proper amount of water before the unit starts and therefore the powder in not dissolved). (3)Any detergent will generally dissolve when contacted with water, unless is has had previous contact with water or is old....
Aug 05, 2010 | Dishwashers
Hoover 200m, keeps letting water in, will not advange to wash cyc
Your outlet hose is too low at the back of the machine tie the hose at about the level as your inlet hose eg to where your inlet hoses are festened and then let the remainder of the hose go to your outlet as usual.that should work Kind Regards Stefan.
Jul 08, 2009 | Hoover HTC243 Top Load Washer
My icemaker will not fill up the ice tray all the way
Your problem is either in the water inlet valve or in the ice maker it's self. It depends on what brand it is. if you can let me know age and brand and modle # I can help you futher.
Apr 01, 2009 | Refrigerators
Electrolux Dishwasher 24 " not enough water new fill valve new float hot water Water lines clear. water too low float never rises amd the dishwasher runs water barly covers the top of the filter straner...
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Jan 23, 2009 | Electrolux Frigidaire Professional Series...
Low water
water level is not detected means there is the problem wiht the sensor
Mar 17, 2008 | Splendide 2000S Vented Washer/Dryer
Dishwashers Logo
Top Dishwashers Experts
