Question about Cannondale Cycling
I'd like to raise my handlebars a little on my cannondale f400.
    Brigadier General:
  • 8,546 Answers
Http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on May 28, 2011
    New Friend:
    Problem Solver:
  • 18 Answers
If you have reached the top of you fork you might be able to slide a one inch head tube into your head tube and then wield it together. you might think about moving your seat back by loosening the allen bolt and sliding it back or get layed back seat post. i wouldn't do anything drastic like the first suggestion to one of my bikes.
Posted on Jan 24, 2013
My handlebars are to low for me is there anything i can put to raise it up so i don't have to bend a little while I'm walking
You can buy handlebar raisers or even handlebars them self that are of different shapes. If you are bending to walk with it you may have clip ons if so try flat bars.
Apr 22, 2015 | Motorcycles
Handlebars allen
If you are asking what size Allen wrench you need to loosen/tighten the handlebars, you are most likely looking at a 5mm. In rare instances, it could be a 6mm or 4mm. As a cyclist, those three sizes are good to have as they correspond to 90% of the bolts on your bicycle.
Nov 10, 2013 | Cannondale F7 CO2 Feminine
P bone service
you need to give more details but it takes some tricky tools that are only used for those cannondale forks. instead of writing directions there is a step by step how to video on youtube if you punch in cannondale fatty shock. it should show you that once you start this project and take fork apart there is no turning back. but if you can talk a dealer into selling you a tool and this video will walk you threw it.
Jan 23, 2013 | Cannondale F400
Raise handlebars up 1"
Yeah, you'll most likely need to get a new stem with the rise. You can also get handlebars that have a rise to them. If your steering tube has space you can add some spacers under the stem but that seems pretty uncommon for a bike shop to assemble a bike with excess spacers on top of the stem.
Aug 12, 2012 | Trek 7.5 FX
Trying to adjust handlebars and hex bolt will not release for raising the handlebars.Any suggestions??
It's not clear which of the two styles of stems you have but it's not all that complicated.
Get a grip (pun intended) on how it works:
If you Google "adjust threadless headset" or "adjust quill stem" you will find many video demonstrations on how to adjust it.
For example:
http://www.youtube.com/watch?v=ZsjZx9Kg7ng
http://www.ehow.com/video_4985708_install-quill-stem-bike.html
For solutions on raising the handlebars...
http://www.sheldonbrown.com/handsup.html
Jun 02, 2011 | Cycling
How to change head set also replace front fork?
Loosen clamp at top of bike frame where seat slides in ...twist seat back and forth while lifting upward.......To remove ft. fork ..At handlebar assy.remove allen bolt..(some are hidden by rubber plug)..remove handlebar assy/remove large nut at top of frame where handlebar slides down in..
...twist and pull to remove front fork....some have upper and lower nut depending which bike.
Feb 27, 2011 | Cannondale Jekyll 600
How do you raise the handlebars
There's a ring nut between the stem of the handlebars (The stem is the vertical part of the handlebars) and the frame of the bike where the handlebars connect into the frame. The handlebar stem goes down through the ring nut into the frame.
Loosen the ring nut and you'll be able to raise the handlebars. There's a mark on the handlebar stem which indicates the highest point that the handlebars can be raised to. If you raise it above this there won't be enough of it in the frame and this can cause the stem to break when pressure comes on it. Also when tightening the ring nut up again make sure you have the handlebars and front wheel lined up.
Jan 16, 2011 | Cycling
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
How do u raise handlebar heigth on f400 bycycle
There are only a few ways to raise the height of your handlebars (the actual grip portion you hold onto)
1) - Raise the stem. How this is done is determined by what type of stem you have.
A. If the stem is inserted via a shaft into the frame, then you must loosen the bolt in the center of the shaft to raise and lower the stem. This has limitations (a line on the end of the inserted portion of stem) you can not go past the max insertion line. If you need it higher, then you need a new stem that allows for more height.
B. If the stem clamps around the fork steerer, then you can only raise the stem as high as the end of the fork. In some cases you can invert the stem for greater height. If you need greater height, then you will have to replace the stem with one that has greater angle.
2) - Replace the handlebars with ones that place the grips higher relative to where the bars clamp to the stem.
In all cases this would be a good project to take into your local bike shop, show them what you have and ask them for the best solution to raising your handlebars.
Things to keep in mind: When you raise the handlebars you increase the distance from the controls to the brakes and derailleurs. If you want to raise past a certain point you will need to replace your cables and housings as they will need to be longer.
DO NOT RAISE ANYTHING ABOVE THE LIMIT LINES: This will cause the bike to be unsafe and could fail causing a serious injury or worse.
Dec 11, 2010 | Cycling
Mountain bike advise
sounds like a pretty good bike for what you will be using it for
Oct 22, 2009 | Cycling
Cycling Logo
847 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
