Question about Maytag ADG7005AWW Gas Dryer
Admiral Gas dryer will start to heat when first turned on then goes cold. The dryer will not stop running but will not heat. Any help would be appreciated. Thank you Jason
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Aug 13, 2011
I have an Admiral gas dryer. It's about 2 years old and today I noticed it is not drying clothes. It is turning on but there is no heat.
heatman101=-
Sep 18, 2011 | Dryers
Hotpoint dryer will not heat - cold air only also the dryer will not stop running unless on no heat setting
heatman101'';;
Sep 08, 2011 | Hotpoint Dryers
My Admiral gas dryer stopped heating up. Model# AOG7005AWW. I have already cleaned all vents. Only cold air blows out of the back tube, cold inside the dryer. Before was taking 2-3 times a cyle to dry for...
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Dryers
My Admiral M938 Gas dryer will start to tumble but makes a wierd noise then stops tumbling and just hums.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Whirlpool Dryers
Problem: the dryer is working, all the functions are good but there is no hot air, just cold air coming out. After few minutes of running "on cold air", it zeros out and stops like it has...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Siemens Dryers
Maybe you can help. The problem I am having is the dryer turns on and runs. The gas lights and the coils get hot. After about 5 mins the gas goes out and the dryer runs cold. After a few mins the gas trys...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 01, 2010 | Dryers
Gas dryer initially heats then heating stops
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
Maytag atlantis gas dry is not heating up its about 6 years old
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Admiral Dryer turn on and heats up but will not automaticly stop after its cycle
Did you have any lint build-up in the vent exhaust ? I need to know before we proceed.
Jan 16, 2008 | Whirlpool LGV4634JQ Gas Dryer
Maytag ADG7005AWW Gas Dryer Logo
267 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
