Question about Maytag LAT3600A Top Load Washer
Top of washer
How do you get the top off?
  • 876 Answers
Here is a diagram of a Maytag top loader. I hope that this helps.
Posted on Aug 16, 2008
How to take the top off of washer?
A step by step guide to take the top off of washer -
Step 1
Unplug your Whirlpool Estate washing machine before attempting to service it.
Step 2
Disconnect your Whirlpool Estate washer from its water supply during repair.
Step 3
Use a small flashlight to illuminate the space underneath the top panel of the washer. Look for two small clips located about four inches in from the edges.
Step 4
Slide a putty knife or flathead screwdriver underneath the top panel of the washer. Find the clips with the tip of the knife or screwdriver, and apply pressure to release them.
Step 5
With the clips released, lift the top panel of the washer straight up. Slide the top panel back and out of your way while you complete repairs.
Step 6
Remove the top panel completely, if desired, by using a screwdriver to unscrew the screws that attach the top panel to the washer cabinet.
Apr 07, 2017 | Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
How do I put the top cover of the washer back? I had the dryer put on top of the washer when it was first installed and took the washer cover off so the dryer can be bolted and sit on top of the washer...
Lay the panel on top of the washer with the screw holes pointed towards the back. Slide the panel forward until it is flush with the control panel. Reinsert the screws in the rear to secure.
NOTE: There should be a couple of tabs near the control panel on most of these washers that the top panel slides into to lock in place.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this help you.
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
Door won't lock on top loading kenmore elite oasis washing machine
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Jan 03, 2009 | GE WPGT9360EPL Top Load Washer
How does the top come off ge washer model wjxr2080t6ww
Use a putty knife to push the spring clips in where the top of the front panel meets the washer top, about 2 or 3 inches in from each side. Front panel pulls forward and lifts off pegs, revealing two 1/4 inch drive hex screws holding top to side panels. If your washer has the lid switch near the front, push the tab on the back side toward the center of the switch and push switch up, then twist 90 degrees and pass switch back through the opening. Now lift washer top at the front side. Most washer tops will unhook from the back side now, but some need to be slid an inch to the side yet to remove once the top is lifted a few inches. If you model still has the lid switch near the back of the washer opening, lift the top at the front and unhook the back of the washer top, pull the top forward a few inches and unplug the lid switch disconnect block. (two wires)
Oct 12, 2008 | GE WVSR1060A Top Load Washer
Washer out of balance
This is a rare brand , couldnt find any info about your unit , but I suggest , since most of the top washer machine ,the top can be remove by using a screwdriver and carefully apply force to open it up , the top is clipped to washer , if you dont see any screws ,
so try it , and hope it works , AJ
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Remove top from Kenmore 101.24722300 washer
rberliner The complete instructions you can find here: http://www.askgene.com/2007/01/26/whirlpool-kenmore-washer-direct-drive/how-to-remove-the-cabinet-on-whirlpool-direct-drive-washer-2/ Gendos...post back
Feb 20, 2007 | Kenmore 24722 Top Load Washer
Maytag LAT3600A Top Load Washer Logo
185 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
