Question about Eidos Interactive Gangsters 2 for Windows
The message 'this program will not run without the cd rom' however the cd rom is in the drive why is this happening???
2 Suggested Answers
SOURCE: Trying to play gangsters 2
I had almost the exact same problem when I tried playing on the weekend, I could play immediately after installing but after I closed the game when I tried to reload it I had the CD-Rom missing message....
I managed to get round it eventually by changing my display settings to 800x600 pixels.
To do this right click on the desktop and go to personalize, then go to display settings, then slide the resolution right down to 800 by 600....
Good luck, let me know if it works.
Posted on Mar 15, 2011
How do I run a set up program
Generally, one enters the BIOS Setup screen by pressing either F2 or Del. There is usually a message on the bottom of the first boot screen that indicates what button is correct for that model.
Looking further into the details that you have given, it seems that your CMOS battery has died, so you will need to replace that. (This is what is causing the "Time of Day Not Set" message most likely.) You can get the appropriate battery at Radio Shack (if nowhere else) for about $5 or $6.
Oct 17, 2014 | Dell Dimension 3000 PC Desktop
HP d220m will not boot from hard drive, have tried several but nothing happens.
Hello, can it be your cd or cd rom that is the problem? I sugggest that you try with a other cd rom and make a copy of your cd and try to install from the new one. Plz post your exact error here.
Apr 05, 2012 | HP Compaq d220M (829160054797) PC Desktop
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
My problem is that almost all of my CD's cant be read by my DVD rom drive in my computer, when I insert the cd it keeps on blinking until it stops and nothing happens, I tested it on the laptop and it...
it sounds like the dvd drive without ,,that's kinda what happened to our cd drive last week, I bought a cd drive at walmart,,but they also have good one at best buy
Aug 26, 2011 | Acer (KV.16X04.007) DVD Drive
Hi this is peter i have a problem hat i nt figer out. trying to install Punch Home and Land Premium i get this-- Error 1305.Error reading From file C: Program Files\Punch! Home and Land Premium\ tool...
Hello peter4927,
An, "Error 1305" message mean that; your computer is unable to read the "Program Disc" properly.
This error can occur if your CD or DVD is damaged, dirty, or caused by dust.
This can happen, if another program is "preventing your computer from reading the "Program!"
You will also receive this error if the "Disc Drive" is damaged or dirty.
Try cleaning the "Disc" first!
"Use a Disc Cleaner, to clean the CD-ROM / DVD Drive.
Place the "Program Disc in the Disk Drive; then "Restart the Computer!"
This will have the CD, or DVD start-up {Automatically}.
Next, you can try to start the "Disc" by using the "Auto-Run."
To do so; place the 'Disc' in the "Disc Drive Tray."
Next, [right click] on the "Computer Icon" to open the 'computer window'.
Now, right click, on the Disc Drive, and select the either, "Open, Explore or {Auto-run}.
Hopefully it will start.
Repeat each action if necessary!
"If there is anything else, you may need help with?
Write a 'comment,' I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Punch Home and Landscape Design Suite for...
When booting the laptop it says PXE-E61: media
When you start your computer, the motherboard searches connected drives for the operating system. The search order is usually the optical (CD/DVD) drive first, possibly a USB drive next, then the hard drive. If none of these work, some systems are set to try booting the operating system over a network cable. What the cryptic message you're getting is telling you is that the system tried a network boot without success, and that maybe the trouble is a bad cable.
This all means that your hard drive isn't being detected, or that there's no longer an operating system on it. It's possible the connector from the hard drive to the motherboard has come loose, which can sometimes happen since laptops get moved around. The hard drive may have gone bad, or there may be a problem with the motherboard that is causing it not to find the hard drive. Or the hardware may all be fine, but something (a virus or other malware, for instance) has deleted files needed to load Windows.
When the computer first starts, you'll see a message about how to enter BIOS setup. The BIOS is the motherboard's built-in program, and through the setup pages you can see what devices it detects. This will let you know if the hard drive is being found. Some boards include diagnostic tests you can run on the hard drive if problems are found. You can also check the boot order; you may find that for some reason the boot order has been changed so that the network boot is being tried first. Strange things can happen to BIOS settings, often a sign that the backup battery for the memory where the settings are stored is getting weak.
If you have access to a Windows XP operating system CD, you can set the BIOS to boot from the CD drive and try using the Recovery Console feature. Information about this can be found at Microsoft's site.
Good luck getting your laptop back up and running quickly. Thanks for using Fixya!
May 29, 2011 | Acer Computers & Internet
CD changer will not play reads "player error" .
Most new car-stereo's don't have an "oldschool" CD-drive, but really a CD-ROM drive; meaning that they won't (properly) read and/or play copy-protected CDs.
Most CD protections are specially designed not to work in CD-ROM drives to prevent copying. As a side-effect most of those protected CDs won't work in car-stereo's.
Try a CD without copy-protection (like an homemade audio CD using burning software on your computer) and see it that works ?
In case that doesn't work either, your car's CD-drive is probably broken ...
Mar 22, 2009 | 2004 GMC Envoy
CD drive door won't open.
there is a very small hole near the push button of your drive, put a pin into it and press it along with the push button
Nov 08, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
The setup wizard on the CD will not automatically run when inserted in the CD-ROM drive, what do i do?
  1. click on start
  2. My computer
  3. right click on CD/DVD Drive
  4. Left click auto run
selecting My Computer, right-clicking the drive that contained the CD-ROM, and selecting Properties. click the AutoPlay tab and select the Select an action to perform option, then double-click the program to use to run the CD-ROM. This action launched the program on the CD-ROM. Note that simply highlighting the program you want to use and clicking OK or Apply doesn't work; you must double-click the program and force it to launch on the CD-ROM or DVD in the drive. The CD-ROM then ran automatically, using the program associated with it on the AutoPlay tab.
Apr 15, 2008 | Computers & Internet
Eidos Interactive Gangsters 2 for Windows Logo
106 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
