Question about Garden
My 7hp tecumseh engine on an ariens tiller will run great until the engine gets really warm. Then it will die. I will restart it immediately and it will run for about 30 seconds and die again. Ive adjusted the fuel mixture several times and also have checked to insure that fuel line is not obstructed. The engine model # HH70-140038c. Any ideas thanks Dan
    Problem Solver:
  • 6 Answers
A few possibilities to check:
1. The chock is stuck on. Pull the air cleaner while running and see if the chock is closing off part of the throttle.
2. Check the OHV valve settings, could be the tolerance is too tight.
Posted on May 27, 2011
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
Nov 10, 2014 | Garden
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
Ariens 8hp Formula rototiller with tecumseh engine- will not start.. have checked spark plug... gas was drained last fall. troubleshooting tips please
well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
May 04, 2010 | Garden
Magnet location on flywheel of a tecumseh 4 hp on a Ariens snow b
what is going on with the magnets on flywheel or are you talking about the magneto ( coil)
Jan 13, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
