Question about Refrigerators
Kitchenaid superba 36 what type of refrigerant is used in this unit? thank you les
    Sergeant:
  • 231 Answers
My be 134A
Check this link to see if it is your fridge the information will be in there.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/211453efe0913d4b85256ab00053d3be/$FILE/4321940.pdf
Posted on May 27, 2011
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
Ice Maker Arm of Kitchen Aid Superba 36
There is trick to putting the ice bale arm back on unless the water cup where the water comes into freezer has the round opening broken that holds the bale arm Click Here=> 628356 Water Fill Cup
Also the video clip from Parts Select will show you the way to do this way of reinstalling the bale arm. If movie does load below then click HERE Telling you how in words would not be as simple as the instructions given in the movie. Thumps up to Parts Select on that tutorial! I will be here if you have questions and please rate if helpful Thank You Sea Breeze
Oct 18, 2011 | KitchenAid Superba Architect KSCS25INSS...
Can we retrofit our 20 year old KitchenAid Superba Refrigerator
Refrigerator efficiency is dependant on multiple things...
compressor efficiency
Refrigerant used
Size/type of evaporator
Size/type of condensor
Ambient temperature
Insulation used and thickness of
There have been some advances in compressor efficiency in the last twenty years but if your unit is using R-12 it would most likely have to be upgraded to R134a due to environmental regulations. Therefore, without a major redesign of your unit to include resizing the system and somehow adding insulation, updating to the newest and greatest compressor will really not gain you much in efficiency and cost as much or more than an entire new unit.
There are still units made without stainless. Unless your unit is a power hungry monster (and yours is not) I doubt a new unit would save you more than a buck a month in power savings.
I wish I could make a recommendation for you but I do not know the market well enough. I know if I were in your place I would hang on to my unit for as long as it works well and continue to save up for a higher end model (with the best warranty/service plan) and look ofr the best replacement out there.
Note: Beware of high end units that are just high priced due to looks. Most units these days are made from the lowest bidder parts (world-wide) and even if they look awsome and have high quality standards during production are subject to the "roll of the dice" due to the cheap electronics used for controls.
Good-luck, Subdriver
Apr 04, 2010 | KitchenAid Superba 21.6 cu. ft. Top...
Superba KEBS277 broken door spring
go to appliancerepairpros.com or repair clinic .com..good luck...
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not making ice in refrigerator.
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath the freezer needs to be0/4degrees to start if not that cold may need freonor compressor my be weak.
Aug 09, 2009 | KitchenAid Superba KFRS361TSS Stainless...
Need ref charge in ozs suct press at temp for superba 42
Refrigeration charge in grams will be found on the label with the model number and serial number. The type of refrigerant is also on this label and the type of refrigerant which is more than likely 134a. You can weight the gas in or you can charge to 10psi, then run unit and adjust up or down as required.
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
