Question about Pasquini Livia 90 Espresso Machine
Hello experts! My older Livia 90 semi will turn on normally (orange and green lights on) , boiler operates, pressure seems to stay at zero for a while, then suddenly rises, only to turn itself off in about 20 minutes (it sometimes will allow maybe 1 shot to be drawn, then drops off pressure and nothing). Steam wand will work as long as there is some pressure left; hot water dispenser sort of dribbles instead of working its way up to a decent flow. After the machine has been turned off for a while (like overnight or several hours) it will repeat this performance. If you try to start it up again too soon, it only turns on -- no orange or green lights. I tried adjusting the pressure stat - no change. Thanks for any advice.
  • waterdogs127 May 29, 2011
    Thank you for your thoughts on this. When you say "try to get an expert to determine...", do you mean I should send it for repairs? Overheating makes sense to me - but I doubt there are any "experts" in my area who could help. There do not seem to be any vents blocked and I did not even know there was a fan in there! Thank you again.
    I do not mean to be argumentative, but is it possible to find someone who actually knows something about espresso machines? I mean, I suspected something similar -- too much heat or too much pressure -- but I sort of lose confidence when things like "fans" are blamed -- maybe those are more appropriate for another type of electronic device?
  • 710 Answers
Hi waterdogs127,
Have you descaled it recently? If you have, then It sounds like either the outlet valve from the pump or the pump itself is going bad.
You could try cleaning the valve to be sure it is clear of crud so the water can get through, then either replace the valve or pump. I am thinking the pump is going since it fluctuates.
You can get parts for it from: >>>> http://www.pasquini.com/
Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on May 30, 2011
    President:
  • 2,047 Answers
The symptoms really do make it ? bit hard to diagnose the unit particularly, but with the issue of what happens when you allow it cool down for ? while this only leaves one chance which is an overheating problem. Somewhere in the system there is a likelihood that the main control panel which is meant to control the operation of the entire unit is suffering from too much heat affecting its operation that's why the system seems to function normal until the heat builds up and doesn't work properly till the heat cools down. The heat could be as a result of the fan on the control board being bad or one or more airvents being blocked or maybe a malfunction in the unit. Try to get an expert to determine what is causing the. Overheating until then try not to put the unit on so as to avoid completely damaging the control board as it still seems in good condition. Feel free to request further assistance. Hope this solution has been helpful?
Posted on May 28, 2011
  • Rockme
    Rockme May 29, 2011
    Thanks for the respone. The only logical explanation is overhetating as I explained. Unless you have the technical know how you would need expert assistance not necessary on coffee machines but any electronics engineer will do but with supervision. Depending on the unit the cooling mechanism mostly has a fan or something similar.
My machine is actually a Bezzera Bz99 which seems to be exactly the same internally as Pasquini Livia 90. The problem is Machine turns on and both lights go on. After a few seconds, relay clicks and green...
I know this is an old post but I have the same issue and need to replace the transformer. How to get in touch with Tyler di Giovanni? Can't seem to find contact info ;(
Oct 27, 2013 | Pasquini Livia 90 Espresso Machine
This Livia 90 has been working beautifully for the last 5 years. Suddenly, the water does not heat up. The needle on the temperature gage reaches the point just before the red marking and then gradually...
Hi
If you open the steam knob before you turn the machine on and it heats up normaly, you need to replace the vacuum breaker valve on top of the boiler. Its the 3/4 hex nut with the little brass pin in the center. If its is stuck closed when the machine is turned off, its holds pressure in the boiler, so when you turn the machine on again it starts to heat up but reaches pressure fast and turns the element off before it heats up all the way.
Apr 25, 2011 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
After several failures, I replaced the pressure stat on my Pasquini Livia 90, only to find that the water would not heat. I put back the old stat, but it still doesn't work. Can anyone help?
Hi
Check the wire on the water reservoir to make sure that it is properly connected.
Check to make sure the wire connection is clean and making good contact.
If the machine turns on the connection is dirty, so you will need to remove nut and clean.
There is a level probe on top of the boiler (actually 2) The right one (yellow wire) is the low level probe and it will not let the boiler turn on unless it sences water at the probe. If it is scaled it can't tell if there is water in the boiler and the element will not heat. Remove and clean the probe.
Jun 03, 2010 | Abernook Pasquini Livia 90 Automatic
This is an early model livia 90 (~1994). Problem is no heating of water. Pump works but neither heating light or pump light comes on. I determined the power relay was not closing. Replaced it with new...
Hi
I would check the level probes on top of the boiler. There is a yellow wire going to the high level( left) and a green wire going to the low (right) probe. The probes get scaled and do not sense water. If there is no sensing of the right probe ( low water) it will not heat. They both need to be cleaned. There is a nut or a big nut that will allow for the removal. Clean both probes and it should go back to normal.
Dec 26, 2009 | Pasquini Livia 90 Espresso Machine
I have a 6 year old Pasquini Livia 90 Automatic. I have replaced the Pressure Stat (4 years ago). Now the machine shuts down after warming up with all three touch pad indicator lights blinking. The...
Hi
there are a couple things you might try. There is a screw in the top of the pressurestat. Turn the screw counter clockwise to lower the pressure.
The light should go off just before the 11:30 position on the gauge.
There are 2 probes on top of the boiler that needs cleaning every so often. A yellow and a green wire connect to the top of the probes. Loosen the small nut about 2 turns or all the way out.
Then pull on the probes to remove then. Sometimes it comes out with the white seal. that is OK. Clean the bottom of the probes and then reinstall.
Yellow goes on the left and green on the right.
Nov 21, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Livia 90 - Power on no pressure
When you say no pressure do you mean steam pressure or water pressure?
If it is steam pressure the machine is not heating up, then the elements could be damaged, disconnect the machine from power open top 4 screws on the top panel, you will see the boiler and element(middle of the boiler with 1 wire on each of the terminals) disconnect both of the terminals and check for resistance between the terminals, if you get a reading then the element is fine.
The bottom level sensor is not reading the water level and told the machine to not heat(stainless steel probe sits on top of the boiler there are 2 of them one checks the min water level and other checks the max water level, disconnect one of them and using ohms meter check reading from the stainless steel level to the top of the boiler, if there is a reading connect and then check the other one using the same method. If there is no reading on any one of those they might be covered with scale buildup or there is no water in boiler.
The machine cannot read the water reservoir(screw with ground connection on water tank).
There is also the Pressure stat(black box which sits on top front right of the machine with 2 electrical wires going to it), remove wires and check with ohms meter.
Mar 27, 2009 | Pasquini Livia 90 Espresso Machine
Livia 90 Semi Automatic pump won't shut off during shot
Bansheracer is possibly correct. But, most likely the problem is the copper feed pipe to the boiler is plugged with calcium allowing the pump to continuously run without stopping. Most likely this is a problem you will need to have serviced. We are located in orange county, CA, and we can service, or Pasquini can service at 1501 West Olympic Blvd, Los Angeles 90015. If you are not in CA, let us know where you are located so we can send you to the closest authorized pasquini service center near you.
Jan 29, 2009 | Abernook Pasquini Livia 90 Semi Automatic
Livia 90 semi auto
I got hold of Pasquini directly and they most graciously talked me through it, admitting the instructions assumed more knowledge than average.  In other words it was a polite way to tell me not to quit MY day job!
Feb 19, 2008 | Abernook Pasquini Livia 90 Semi Automatic
Pasquini Livia 90 Espresso Machine Logo
63 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
