Question about Radio Shack Pro-84 Handheld Scanner
Pro 84 locked up says on screen in program mode wired
    New Friend:
  • 3 Answers
NAAAH, don't reset it. Check the programing cable jack. It may have a bad solder joint or a bent element.
Posted on Jul 03, 2015
    President:
  • 2,761 Answers
Your scanner should only enter the WIRED mode if you have a clone cable plugged into it. The only way to clear the problem is to RESET the scanner. Unfortunately this procedure will also erase all the frequencies that are programmed into the scanner. RESET is covered on page 54 of the scanner manual -- if you don't have yours you can download and print a copy here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
Bill B.
Listening in since the 60's
Posted on May 28, 2011
My pro-95 scanner screen reads all channels locked out! How do I get it back to working mode.
hello firstly select the mode and bank number ,press and hold L/o button this will unlock all channels and ready for programming you will notice that the L/O button is now removed from the screen
goodluck
Apr 19, 2011 | Radio Shack Pro-95 Handheld Scanner
I don't know how to program the pro-84 scanner.
The best programming instructions for your scanner are in the factory manual that you can download and print, at no cost, here:
You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, here:
www.RadioReference.com
Bill B.
Feb 14, 2011 | Radio Shack Pro-84 Handheld Scanner
It appears to be locked in "wired" mode.....how do I clr this code? I have never attempted to hook the unit up to our computer so I don't know how the code has appeared.
The best way to clear this glitch is to RESET the scanner to original factory settings, but beware -- this action with erase all data that you have programmed into the scanner. The scanner is useless if locked in the WIRED mode though, so I recommend the RESET.
- Power the scanner OFF
- Press and hold the 2, 9 and HOLD keys while you power the scanner ON
- The word CLEAr will appear after about 3 seconds. Do not power the scanner OFF until this message is gone from the display.
If you don't already have it, you can download and print your scanner's operating manual here:
Bill B
Sep 27, 2010 | Radio Shack Pro-84 Handheld Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
When i turn my pro-84 handheld scanner it says
Your scanner should not enter the WIRED mode unless you have a data cable attached, so you will need to RESET the unit to restore normal operation. To do this, power the scanner OFF, then press and hold the 2, 9, and HOLD keys and power it back on.
NOTE: The RESET will erase/delete all data that you've programmed into the scanner, but it's the only way to clear your problem.
Need the manual for your scanner? You can download/print it here:
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Bill B
Jul 09, 2010 | Radio Shack Pro-84 Handheld Scanner
PGM WIRED
pgm wired how do i fix this?
Sep 19, 2009 | Radio Shack Pro-84 Handheld Scanner
MY pro-94 said on the screen lu,red or something like that !
Could the display be saying "wired"? This is what it shows when it is in cloning or programming mode. If it is showing this and there is no programming or cloning cable attached, check the programming jack to see if it is damaged.
Aug 10, 2009 | Radio Shack Pro-94 Scanner
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-84 Handheld Scanner Logo
337 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
