Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
I have service call 0092 on a 1650 EN km printer. Have had bad prints from the machine replace old toner cartridges with new ones from konica (the old ones were generic brand) was told i could clean the green roller and tried now the printer won't work
  • 214 Answers
SOURCE: How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Posted on Feb 09, 2008
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
Posted on May 27, 2008
SOURCE: Konica Minolta Magiccolor 2350 Laser Printer
When the front door is open, it locks the 4 cartridges so they can not move. The tab is flimsy & I broke mine on the second or third change. It pushes on a mechanical switch just above the toner port. If you broke the tip of the tab off, you can use a drywall screw inserted into the Mechanical switch. when the door closes the bigger part of the tab will push the screw against the switch,
Posted on Aug 26, 2008
namizhka
  • 148 Answers
SOURCE: Konica Minolta magicolor 2300W printer
TRY TO RESET THE UNIT FIRST.
Posted on Sep 29, 2008
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
Konica Minolta 2400 laser printer has a slow, 52 times per minute, yellow lightning bolt flashing on its control panel on the front right of the machine. It seems to be locked up. It wont print or r
Sir bad idea to replace with partial one. Replace with OEM cart Brand New machine counts how many prints for several different parts in the machine when it reaches certain counts on certain part it wants NEW stuff.
Dec 18, 2014 | Konica Minolta Magicolor Model 2400w Color...
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Service call 14A3 in km 1690mf
The bright light that reads the image of the original document is bad replace it. comes as the scanner
try this site for start
May 29, 2014 | Konica Minolta magicolor 1690MF All-In-One...
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Feb 13, 2014 | Konica Minolta Di200 Di200f Di250 Di250f...
I have a Konica Minolta Magicolor 1600w which has not been very reliable. After a year I had to replace the fuzer. When the toner ran out, I decided to buy another one since it's cheaper than buying...
the second printer who made that? you bought a new 1600w?? and no you can not use the new cartridge in the old. go out buy new OEM cartridges for the printer the first one. on the new printer. did you clean the rollers did you ensure the printer setting for the media (paper) was the same as on the computer. was paper properly installed landscape versa porait.
Mar 24, 2017 | Konica Minolta Magicolor 1600W Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 5430 showing wrong toner levels
Are yo using genuine Minolta toner? Some generic toners do not replace the chip on the cartridge which tell the machine the toner levels. If this is not the case let me know. John A.
Jun 29, 2007 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
785 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
