I cannot copy cd to cd the system is not in oporation
    Master:
  • 377 Answers
WHAT COPY OF CD YOU WANT TO TRANSFER ON YOUR PC...?
Posted on Aug 16, 2008
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
Tip
How to do System Restore when the computer doesn't even boot to Safe Mode in...
System Restore is assumed to be the best method to recover the system from Registry or System file errors. Its easy to perform and is effective, no doubt. But what happens when the system doesn't even boot to the desktop, neither in Normal mode, nor in Safe Mode. How do you do a System Restore then. For Vista and Win 7 users, its a piece of cake, since the WinRE provides them the direct option to System Restore from the installation/repair CD. But what for the XP users?
The following method is very useful and serves as a bliss for Windows XP users to recover their system from crashes due to Registry or System file failures. All you need for the method is a Windows XP installation CD. (This is not a re-installation process. All data and settings are intact after the operation.)
Step 1: Boot to the Recovery Console
  • Insert the Windows XP CD into the computer.
  • Turn the computer off.
  • Setup the computer to boot from cd: either by pressing F2, F9 or Delete to go in BIOS and changing the boot sequence or by pressing F12 on Dell computers to launch the Boot Device Menu.
  • As soon as you get the message 'Press any key to boot from the cd', hit enter.
  • Wait for the Windows Setup to initialize
  • At the Welcome to Setup screen press R to repair windows using recovery console.
  • You will be prompted to choose a Windows installation. Press 1 on the top of the keyboard and then press Enter.
  • You will be prompted to enter the Administrator password. Press Enter if no password was set.
Step 2: Accessing the Restore points.
Type the following commands in the Recovery Console.
cd system~1
If you get an Access Denied error:
  • Type the following commands to change the directory to c:windowssystem32config:
    cd windows
    cd system32
    cd config
  • Rename the system branch of the registry. That will allow us to access the system restore folder from inside the Recovery Console. In case the process fails and you want to perform a Windows Repair you will need to rename system.bak to system again.
    ren system system.bak
  • Type exit to leave the recovery console and to restart the computer.
  • Go back into the Recovery Console and repeat Step 2.
cd _resto~1
If the _resto~1 folder exists, inside it there are several folders named RP1, RP2. These are restore points. RP1 is the oldest restore point. You can use dir to view what RP folders are available. If there is no _resto~1 folder or if there are no restore points inside it:
  • Type the following commands:
    cd
    cd windows
    cd system32
    cd config
    copy c:\windows\repair\system system
  • If you are getting a file not found error try:
    copy c:\windows\repair\system.bak system
  • Then type the following :
  • copy c:\windows\repair\security security
  • copy c:\windows\repair\software software
  • copy c:\windows\repair\sam sam
  • copy c:\windows\repair\default default
  • exit
  • You will be able to boot into a altered version of the operating system. Backup your files from the c:Documents and Settings folder and then reinstall the operating system.
Step 3: Choose the most convenient RP folder.
Supposing we have RP3 available let's type in:
cd rp3
Change the directory to snapshot:
cd snapshot
Step 4: Restore the main registry branches.
If you are being asked if you want to overwrite type in y to agree.
copy _registry_machine_system c:\windows\system32\config\system
copy _registry_machine_software c:\windows\system32\config\software
The following commands are most of the time optional however the process might not work if they are not executed
copy _registry_machine_security c:\windows\system32\config\security
copy _registry_machine_sam c:\windows\system32\config\sam
copy _registry_user_.default c:\windows\system32\config\default
Type exit to reboot the system. Start the computer normally.
Thanks,
Abhishek
on Mar 22, 2010 | Microsoft Windows XP Professional
Install F2120 hp deskjet All-in-one program
please give a littlew advice about your computer oporating sytsem windows xp windows vista? windows 98se? also please check if it is a 64 bit oporating system or 32 bit, windows system information tool in tool acessories system informationwill give you all the info you need. then just click catagory and select copy or save or export the fiole to desktop and copy to notpead or forum for review, sounds like you need the all in one software to run on a im asumming windows xp computer and tyhe software is not running this can be cause microsoft windows update service and bits is probably turnedoff, if you update the microsoft critical updates and recommened updates things will start to run due to out diated installer files and windows also might require a few updates to run the installer class files. hope that help you. and good luck.Please note: thease are basic sugestuions tyou can try theirs far more complex things but this is going to easily determ the what needs to be done next.
Aug 20, 2009 | HP Office Equipment & Supplies
HS on read out
to access the service mode.you need to PRESS the the folowing.. BOTTONS.using the the oporation panel.PROGRAM INTERPUPT CLEAR ITERUPT .THAN ENTER # 14 THAT START BOTTON
HOPE THAT HELP
Dec 28, 2008 | Sharp Office Equipment & Supplies
I cant install my creative live web cam
Hi
please follow me with following stepes so you can solve this problem.
since there is not enough informations on your question , so we start from begining.
plese click on start from popup list click on control panel .and open it,
chose add remove programs , make sure if your web cam is listed or not , if it is please click on remove and follow the screen.
after removing ,
duble click on my computer icon and chose Drive C ,if it is your main hard drive (mostley C is main hard drive with oporating system instaled, if not chose what ever letter shows your main hard drive)
doubl click omn it and click on progaram files , from next page find your webcam folder and delet it ,next emty your trash bin,
reboot your pc , and put your webcam CD in cd drive (do not conect your webcam) after instaling driver out of cd ,if it asked you to conect your webcam during driver instalation do so please,).
if it did not ask you , finish your instalation reboot (restart)your pc , now conect your webcam,
wait until windows find your hardware and follow the instructions.
i hope this solve your webcam problem .
if you need more assistanse please let us know.
thanks :Marco
Dec 13, 2008 | Creative Labs WebCam Live!
Installing new oporating system, laptop can't find the hard drive
your hard drive might ne bad. most toshibas have a hard drive test utility use it and check the drive set drive to master if it has jumpers
Dec 05, 2008 | Toshiba Satellite A100-S2311TD Notebook
Disc driver will no longer work
Please copy and paste this link or click on it. Follow ComputerDave's directions. Very easy and works perfect. Had same problem as you with Toshiba laptop. Good Luck!
http://www.fixya.com/support/r380953-missing_dvd_cd_rom_drive_letter
Oct 26, 2008 | Toshiba Satellite A205-S4617 Notebook
JVC TH-A10
Have the same unit and it does not have the capability to play anything other than commercialy produced CD's or DVD's i.e. no CD-R CD RW
Dec 25, 2007 | JVC TH-A10 System
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
