Question about Maytag MZD2766G Side by Side Refrigerator
I purchase a Maytag Wide by Side refrigerator for my parents and the Refrigerator keeps freesing up all of the food. Tryed Defrost but not working. Model MZD2766G
  • Maytag Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on May 27, 2011
The automatic defrost cycle is not working in freezer. Can this just be low on freon and making it freeze up? I can defrost and refrigerator will work fine till it freezes up again.
Most times on your model it is the ADC or adaptive defrost control. Part number 13 in photo here=> MSD2756GEW Maytag Refrigerator Control Panel This is behind your controls inside your fresh food compartment.
61005988 Adaptive Defrost Assembly
When the fresh food compartment begins to get too cold is usually when the part #8 in that photo goes bad and that is called the auto air damper
61005971 Damper Control Assembly
More on that part next time. I believe you will be fine once the ADC is changed, Thanks, Sea Breeze
Mar 19, 2011 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator does not cold, food problem
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 20, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Model # MSD2957AEB side by side refrigerator and the coils in the freezer part each month seem to freeze up. This causes the cold vent leading to the refrigerator to stop the cold air...
the metal piece is the defrost terminate thermostat the adaptive defrost control is in the food side .top where the control are and lights . on the right not hard to miss
Sep 27, 2010 | Maytag Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
My maytag wide by side keeps freezing up. I have
It's determined by how much you are in and out of the unit,the board uses the light switch to count how many times you open and close the door if the switch isn't working properly it won't defrost often.Under normal usage you should get at least 2 defrosts in 24 hours.
Aug 19, 2009 | Maytag Refrigerators
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator is not cold but freezer is operating at full capacit
Most refrigerators have a damper door that is controlled by a knob that lets some air from the freezer compartment into the refrigerator compartment there is also a fan that blows this air into the refrigerator. Sometimes when the defrost timer quits and ice forms it causes this fan to break or quit .Please understand the original problem was probably caused by the adaptive defrost circuit or defrost timer which is still failing Also the unit needs to be defrosted completely and the evaporator fan checked for proper operation.there is a way to put the unit in the defrost mode.Usually there is a diagram on Maytags stuffed under the thermostat panel .Make sure to unplug when probing or testing or have knowledge of how to work on live circuits .
Nov 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
MZD2766GES Maytag defrost problem
in fresh food part on top right, remove the housing assy.
Jul 21, 2008 | Maytag MZD2766GES Side by Side...
Maytag wide by side.
If it happens again, check the defrost timer. If it does not self defrost, the cooling coils (evaporator) get plugged with ice and although it is frozen, the ice stops the transfer of heat. Unplugging the unit allowed it to defrost so air could circulate again.
Jul 08, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MZD2766G Side by Side Refrigerator Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
