Question about Frigidaire PLHS67EESB Side by Side Refrigerator
Broken water actuator on Frigidaire Model PLHS67EESB4 side by side fridge. how to change the part out?
SOURCE: Replacing water actuator on side By Side frigidaire
trying to bring temp down on the fridge side.first i tryed to just turn the temp up. Waited over night no change. Went back to factory setting,still no change. Fridge still under waranty all ready has a new copressor and invaporator installed by fridgaire. The fridge is only a 03 alittle young to have these problems.
Posted on Dec 14, 2007
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
techcrazy
  • 72 Answers
SOURCE: broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Posted on Feb 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: changing out actuator
If you are speaking of the water dispenser actuator the parts ar removed from front of the dispenser control panel. Visit my site and enter model FRS26TS7DB5 into the model search feature. once there look on left of screen and choose photo # 15 it shows a breakdown of the parts. We also offer free help and assistance. Click link below, Thanks Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Mar 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: need to replace the water actuator on frigidaire model FRS6B7EESB
To get help replacing the actuator you can visit mu site below and enter your model number FRS26R4A in search feature this will take you to the parts page. On left of screen click picture #15 dispenser. I shows a diagram of the parts and I or Appliance Parts can assist you in installing the actuator. Thanks Sea Breeze sea breezehvac@yahoo.com
click on link below
Posted on Mar 30, 2009
I have a frigidaire gallery series side by side and everytime the fridge says the water filter needs to be changed now it leaks a good bit of water from the bottom of the fridge.
There is an O ring that will leak water into the overflow pan under the fridge. I'd clean the pan too to eliminate bad odors. You must shut off the water supply before changing the filter element. There is no shut off valve built into the filter or its housing.
Aug 08, 2015 | Frigidaire Refrigerators
Need to replace the water actuator on frigidaire model FRS6B7EESB
click on link below
Mar 29, 2009 | Frigidaire FRS26R4A Side by Side...
Changing out actuator
Water and ice not dispensing on Frigidaire side by side
We have a similar fridge were told that it has a resivoir inside that needs to fill with water before it will start to dispense water. Had to stand holding in the actuator for quite a while befrore it started putting out any water. Shoud be the same with the ice maker, but there is an arm inside the freezer that controls how much ice you get it could be turned off.
Jan 24, 2009 | Frigidaire FSC23F7D Side by Side...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Nov 24, 2007 | Frigidaire FRS26R4A Side by Side...
Bypassing a filter
They do make a bypass for this which you can get at http://www3.sears.com/.  Will need to know the entire model # from the sticker on the inside of the fridge.  If you have trouble let me know.  I would the the model # also to help further.  Also, it may say something about it in the owners manual.  Let me what you find.
Oct 17, 2007 | Frigidaire FSC23F7D Side by Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Frigidaire PLHS67EESB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
