How do I restore file from my Maxtor onto a new computer
  • 23 Answers
That highly depends on what you mean by restore, if you're Maxtor is not formated or the file hasn't been deleted, you can simply buy an enclosure (It's a case for Hard Disk Drives) specifically for the cable of your Maxtor (IDE or SATA) to USB 2.0, you should be able to get an enclosure in any place that sells computers, or you could get one from amazon. If by restoring you mean that you've deleted the file or you've formatted your HDD, there's one software that can help you recover it, the name of this software is Pandora Recovery, just install it.After installation, make sure to choose the option that reads "Surface Scan", then you can specify the kind of file you're trying to restore. Finally, choose the drive from which you want to restore the file from and then hit the "Start Disk Surface Scan", depending on the type of file it will take a while,also, it will not have the same name that when you deleted it, so make sure to restore as many files as you can that you think has the amount (in KB) that the original file had and check if it's the one you need.
Posted on May 27, 2011
My computer crashed a few days ago and my one touch mini 4 was used to restore most of my files to my new computer. Before I start using my Maxtor mini4 on myu new computeer for back, do I need an...
Hi, the new computer should recognise the OneTouch and find the right drivers when you plug it in.
The SafetyDrill recovery CD does not have the drivers on it. It is just for use as a boot disc if you want to completely restore your PC with a SafetyDrill copy which has been made earlier.
There is no installation CD but the Maxtor Manager utilities, including SafetyDrill, were originally on the OneTouch drive itself and should still be there if you explore it. To install Manager click on the icon called 'Launch' (which is a green forward triangle/arrow with an orange square off centre on it)
The 'guides' file should still be on the drive too.
Jan 06, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
Transfer files to a new computer?
From Maxtor's web-site, download the "MaxBlast" software.
Use it to "clone" your existing disk-drive onto your new disk-drive.
It works, and it works _very_ quickly.
Other than that, use the Windows "Files and Settings Transfer Wizard" (under System Tools, under Accessories, under All Programs) to select what you want to copy (E-mail? contacts? Files? Music?) and to burn one "aggregate" file onto a DVD-recordable disk.
Then, use the same Wizard to "import" from that disk onto the new system.
Dec 18, 2010 | Maxtor Hard Drive
Can I put stuff from a comp. w/ a virus onto a maxtor hard drive
Yes, naturally it depends on the virus, what kind it is and where it is stored. Most of the time you can safely transfer files to another hard drive worry free. I would not use a program such as "Ghost" that copies all your system's drivers over. Only save necessary files, format your old hard drive and re-load everything.
Hope this helps,
Thanks
Jan 16, 2010 | Maxtor Hard Drive
Hi, I lost user manual, need to restore files back to computer.
Provided that you can find your external drive using My Computer feature, double click on that drive icon and search the drive for the files you wish to put on the computer drive (C drive). If you right click the file or folder on the Maxtor external drive and then choose copy, you can go to the folder on the C drive that you want to paste them into, select it and then right click the folder icon and choose paste to put them into the folder. To make the process quicker, you might choose to paste all files and/or files from the Maxtor drive onto the computer desktop and then move them around later.
Dec 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Help
Well Is your Jumper Pin is in the correct setting?
Is your maxtor in slave master.......
try changing them and see what happens next..
Mar 07, 2008 | Computers & Internet
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Maxtor 320 usage instructions
The new hard drive should be showing up for you in "My Computer". If it's showing up there you can just start copying files onto it.
Jan 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Restoring deleated files.
Maxtor has been acquired by seagate. maxtor did send out recovery software to the general public on request, but i am not sure if that is still the case, You can contact them at....
http://www.seagate.com/www/en-us/about/contact_us/
If the drive is not physically failing, try drive genius.
Keep me posted.
Nov 05, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
