Question about Volfenhag ZX-7180 Car Audio Amplifier
What size of fuse do I use - Volfenhag ZX-7180 Car Audio Amplifier
  • 22,326 Answers
Easy divide volts into watts and this will give you the amperage so a 12v x200 watt amp needs a 20 amp fuse
Posted on May 27, 2011
What is the difference between a ATC fuse and a ATM fuse ?
ATC Fuse
  • ATC fuses were created before ATM fuses. An ATC fuse will be larger than an ATM fuse in physical size. This is considered to be the regular size. An ATC fuse will be found in late-model electronic devices.
ATM Fuse
  • An ATM fuse is considered to be a mini fuse and it came out in the early 1990s. The only difference is it is smaller than an ATC fuse in actual size. It generally cannot be used in a fuse block that is made for an ATC fuse, as it will not fit in properly.
Apr 24, 2015 | 2002 Mazda Protege
Find out what size fuse for my Peugeot partner van
the amp size of the fuse is on the fuse. when you take it out look at it and you will see the number. some of them are on the fuse by the fuse itself.
Mar 02, 2015 | 2006 Peugeot 405
Location of fuse box
There is no way on earth to answer your question without knowing what year, make and model vehicle you are asking about. Also, You ask what size fuse. There are many size fuses. Are you asking about interior lights, signal lights, tail lights, stereo, a/c or what?
Nov 08, 2014 | Cars & Trucks
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
What causes back up light fuse to blow when replaced with a new one
the fuse is the wrong size or the manuals suggested fuse is not the correct size. Try replacing the fuse with one size larger . xoxo
Jun 29, 2013 | 2007 Ford Expedition
Concerning fuses, dash board and tail light use same fuse, size 10 fuse could I use a size 20 fuse in its spot and would it be harmful to use truck ?
In a pinch, yes you can use a 20amp in place of a 10amp as long as you have repaired what blew the 10amp.
It needs to be changed to the correct 10amp ASAP.
What happens is the next time, the 20 becomes a 30, becomes a 40 becomes a ... and the wiring harness burns up.
Feb 06, 2018 | 1992 Ford Ranger
My interior dome lights do not work and neither do my power locks, i am sure this is the same fuse, i open the fuse box in the engine and there is a fuse missing and it is labeled done, i read my owners...
Are you putting in the right size fuse? Your owners manual should direct you to what size fuse to place in there, and be sure to use this size. don't use a higher size, as it could cause a short and/or fire.
If you are using the right size fuse.. then you have a short in that system... somewhere.
Jan 07, 2011 | Lexus ES 300 Cars & Trucks
Size fuse for blower motor
Fuse sizes in car commonly using color coding. There red, white, blue etc. The color fuse is indicate current rate. So if your blown fuse has color is red ( for example), just change it 'new' red fuse. Fuse size of blower motor normally will not exceed 20 Amps.
Nov 28, 2010 | 1992 Ford Explorer
My hotpoint tc71 drier blows the plug fuse when switched on what is the problem please
boy the list could be very long but this dyer draws a large amount of current (amps) it should be on its own circuit nothing else on the line at least when the dryer is running you said "fuse" if it is blowing a fuse as opposed to a breaker you could try a Time Delay fuse 15 amps might help please do not put a larger fuse in (even though it fits) the wire size dictates the size of the fuse and increasing fuse size with out changing the wire size to accomodate will create a fire hazzard good luck
Oct 23, 2009 | Hotpoint TDC32 Electric Dryer
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Volfenhag ZX-7180 Car Audio Amplifier Logo
62 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
