Question about Zanussi FJS1225W Front Load Washer
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
  • Zanussi Master
  • 1,525 Answers
Hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
Posted on May 27, 2011
Replacing drum bearing on a ZANUSSI FJS 874 front loader ?
This is not a simple job, it can be fine but requires the complete disassembly of the machine to change the bearings, there are 2 bearings and a seal that require replacement, I can assist in guiding if you wish to do so, it takes around 3 hours total to strip and rebuild.
Jun 16, 2016 | Zanussi Washing Machines
Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
Unscrew anti-clockwise to remove and clean.
Jan 31, 2010 | Washing Machines
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi FJS1197 w ashing machine making knocking noises when spinning
There is an answer at this link:
http://www.howtomendit.com/answers.php?id=16357
"some you can get at and some you have to lift over the top, when you get there you will need to smack the bearings out, maybe a old socket set with a long tube just to fit inside the bearing hole?. for what its worth go to the tip you might find one, that just wants a door seal?"
You must have some technical experience.
good luck!
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Settings dial has broken on my Zanussi WJS - 1397W
You can go to this site and find/order the parts to fix it. It looks like the top of the machine just pops off (held down by clips) which then exposes the control panel and allows access to fix. Hope this helps.
http://www.espares.co.uk/diagram/washing-machines/zanussi/wjs1397w/p/1085/332/0/407647?ed=3912
Oct 27, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi FJS1225W Front Load Washer Logo
228 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
