Question about Vacuums
Electrolux epic series 3500 sr serial v87779 l
I have an electrolux epic series 3500 sr serial v87779 L
The machine will turn on, but the brushes wont turn. The belt is not broke, nor does it appear stretch. Any suggestions would be most appreciated.
Thanks in advance
Becky
  • wbigler Nov 03, 2008
    I have the same problem. Looks like the motor is dead and my online search hasn't produced any hits on replacement parts. The the numbers on the motor (not sure which is the part number) 6700-91 and ECP HDA.
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Posted on Nov 05, 2008
SOURCE:
How to change belt electrolux epic 3500 sr
See my other posts for the directions for change. Hope this helps!
Jun 19, 2014 | Electrolux Epic 3500 Vacuum
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I need an Electrolux EPIC 3500 SR Manual. Can I download one on line? Judy Lewis
Hello Judy,
Below is the link for the manual you are requesting:
http://www.manualsonline.com/mdownloads/71312b47-cc60-4884-e1fe-e29af72fcfa1.PDF
Please let me know if you have any questions or concerns. Please rate this!
Thanks,
~PCF
Mar 15, 2011 | Electrolux Epic 3500 Vacuum
What kind of bag for the epic series 3500 sr
"U" (upright) style bags, available at any Aerus Electrolux store, or from their consultants. These are the genuine bags made only by Home Solutions. Generic bags WILL decrease the lifespan of the motor.
Contact your local dealer. Free home delivery.
http://www.aerushome.com/storelocator/
Nov 15, 2010 | Electrolux Epic 3500 Vacuum
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
My Electrolux series 3500 SR won't power on.
Most likely the cord has a broken wire you can't see (near the plug) or; the switch is bad.
Either is a fairly simple repair.
Charlie
Aug 21, 2009 | Electrolux Epic 3500 Vacuum
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
1,056 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
