Question about Whirlpool Washing Machines
How do I get the filter out of my awm5145 washer. It is at the bottom on the right but nothing seems to move it.
    Sergeant:
    Champion:
  • 257 Answers
It Should turn counter clockwise and then pull out. Sometimes they can be a little hard to turn, You can use gloves a towel to get a good grip.
Posted on May 27, 2011
AWM5145/2
check if water pump dont release water properly..u can see that in the end of drain hose ..fill the washer w/ water then set it to spin after that look the hose if the water flow properly..
Mar 08, 2014 | Whirlpool AWM5145/2 Front Load Washer
Clogged draining boot?
Check the drain filter and the drain hose at the back.
Drain filter access is located in the fro lower section of the front size. You need to remove the trim at the base of the washer and to undo the cap, turning it counter clockwise. Disconnect power before starting and keep a container ready to collect the water.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
I moved and it seems that a plastic piece came loose inside the machine and was laying on the bottom/ It is a rectangular piece and i cannot seem to find the right placement of it. Can you help?
Not a lint filter is it with a mesh bag attached? It may slot into the side of the bowl towards the top somewhere.
If thats not it perhaps you could describe it a little more.
May 21, 2010 | Haier HLP21E Top Load Washer
PE235 would not spin or empty. Now it wont cycle either
Check the filter at the bottom of the machine ,right hand side behind the plastic cover along the bottom. You may find a blockage in there.
Adrian
Aug 06, 2009 | Hoover PE235 Front Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Put on a program, dial moves only a little bit, no water going in, nothing happening. If I switch it to drain it sounds like it is draining.
check to see if the motor is faulty,remove the back panel and belt and turn the motor pulley by hand there were faulty commutators in some of these motors.(macking a clicking sound) if so you will need a new motor.
Feb 29, 2008 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Nov 27, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
