Water, less than a quart, leaks into the washer after the cycle completes and the clothes have been removed.
  • 127 Answers
You might have the drain hose to high, or it is partly clogged.
Posted on May 27, 2011
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Water Leaking on floor.
probably the water dispenser valve.
Apr 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes still too wet after complete cycle
I would suggest that the filter wants cleaning.
To access it, remover lower rear panel of washer.
Locate and remove the large black hose on to the tub.
Be careful, as there will be water in the hose.
Remove and clean plastic filter inside hose.
Refit hose and filter..
I would also suggest that you remove motor and check the brushes for wear, whilst you have the rear panel off.
If there is less than 10mm showing, then they need replacing..
Please leave a rating for my fixya solution.
Thanks.
Feb 07, 2009 | Hotpoint WMA54 Front Load Washer
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
