Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
How do you clean the metal wire grid at the bottom of the refrigerator after you remove the toe kick panel. When it is removed you can clean the first wire grid, but the slanted grids behind it aren't accessible to vacuum all the pet fur that gathers there.
    Master:
    Sergeant:
  • 385 Answers
Ylou can purchase a special brush that will get in there.Hardware stores will usually have them.
Posted on May 27, 2011
  • lochmom May 28, 2011
    Thanks,I have tried that, you can get to the first grid but not the ohters that are behind it.
  • Tony Wisinski May 28, 2011
    If you really want to get it all out you can blow it out with an air hose. I have done that but it makes a big mess.
Top & bottom are not cold enough.
Check to see if there is any ice buildup in the back of the freezer. You may have a defrost problem. If no ice is found, you may have a Freon leak. Also, what is the make and model number of the unit?
Jul 20, 2011 | Amana Refrigerators
Im trying to find the power supply hook up for the dishwasher
The power supply hookup on a dishwasher is located underneath and to the fromt of the dishwasher. Look at the very bottom front of the diswasher, where the toe-kick would be on your cabinets. You will see that this is actually a removeable panel held in place with a couple of screws. Remove this panel and you will see a metal box, also with a removeable cover plate. Remove this cover and you will find the power supply wires. Strip the wires from your Romex supply line and wire nut those to the dishwasher wires, blcak to black, white to white, and the ground will loop under a green grounding screw located in the inside of the box. Hope this helps.
Apr 30, 2011 | Dishwashers
I am able to access the back of the condenser coil to clean it but cannot get to the front of it. Using a flashlight from the front I can see that the coil is totally caked with dust. How can I get to the...
get a shop vac and a condenser coil brush,you can buy it at any appliance or hardware store,you stick the brush into the coil and the dust sticks to it or falls apart onto the floor or i use a shop vac,one end vacs the other end blows,i vac up as much as i can and then blow the rest off of the coil,you can remove the bottom back panel and blow it to the back wall and then vac up the dust that blows to the back
Feb 25, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Oct 31, 2009 | Miele KF7642S Bottom Freezer Refrigerator
Blown fuze
moz-screenshot.jpgmoz-screenshot-1.jpgYou should be able access fuse by removing the toe kick panel at the bottom front of your unit. They will on the front side of the transformer pan,
Mar 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Kenmore dryer (electric )
Almost always a thermal fuse.
If your lint screen is in the door, follow these directions:
Disconnect the power. Remove the lint screen. Slide a putty knife in between the toe panel and the bottom of the door three inches from either side. this will release the clips at the top. Tilt the toe panel out at the top and lift it off the clips on the bottom.
Remove the two 1/4 in screws at the top of the metal triangular box around the lint screen. There may be one more ***** near the bottom right of the box holding a gold bracket in place. Remove that ***** or lift the box off the black metal clip at the bottom.
You can now reach the thermal fuse. It's the white plastic part with two wires on it near the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
If your lint screen is in the top of the machine, follow these directions:
Disconnect power. Remove the lint screen. Remove the two Phillips screws under the lint screen handle.
Pull the dryer away from the wall about 2 feet or more. Disconnect the vent pipe from the bottom of the dryer. Remove the nine 1/4 in screws holding the back panel on, along with the small metal cover. Lift and remove the back panel.
You can now reach the thermal fuse. It's the white plastic part with two wires, close to the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
While you're back there, be sure to clean out the long metal box that the lint screen goes into (four more 1/4 inch screws.)
Mar 12, 2008 | Kenmore 63942 Dryer
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
