Question about Harman Kardon AVR 230 Receiver
I have a Harman kardothe hdmi n avr255.There is no audio output from one of the HDMI input.I need help on this one.
  • Harman Kardon Master
  • 6,694 Answers
You have to check the audio assignment of the corresponding HDMI input. May be it is assingned as optical or coaxial. You have to change it to HDMI. If you have the User manual just read the audio assignment settings.
ok
Posted on May 27, 2011
Connect pc
To connect your PC or Laptop to your Harman Kardon AVR 2600 you need to connect the HDMI cable output of your graphics card to one of the 4 HDMI inputs on the AVR 2600 receiver. The HDMI connector on the AVR 2600 labeled "HDMI Monitor" is on output and cannot be used as in input.
You need to select the corresponding input from the front of the AVR 2600 or using the remote. Next you need to make sure your have the HDMI output port selected on hour graphics card. This will probably not apply to your PC, but may require some settings from the function keys on your Laptop.
Note that you will probably need to also connect audio from your PC to your receiver as well. I would recommend you use HDMI cable with ver1.4 specification so that you have the best chance of getting audio over the HDMI. If you only get video, then run separate Toslink (optical) or RCA cables to get the audio to the system from the PC.
Jan 12, 2014 | Harman Kardon AVR 2600
Hdmi output and inputs are no working. Only one works and I have to use it for everything just unplugging it and plugging hdmi cable running from bluray or game into cbl
I understand from your original message the main HDMI output works, and only one of the HDMI input is working. Which HDMI input is working? Bluray, Cabl/sat, or Game? Are you able to select the working HDMI input either from the remote, and front panel of the receiver, or just from input of the receiver?
Double check your settings for Audio output and HDMI controls (found on page 36 and 37) of the owner's manual.
Jan 06, 2014 | Onkyo HT-S3300 Theater System
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
I have a harman kardon AVR 132 and have just purchased a Samsung UA55D7000. I am running HDMI from the sammy to my ps3 for video and then an optical cable from the ps3 to my HK for audio and im having...
Hi, You might want to run your ps3's hdmi into your hk, as I'm sure it has hdmi inputs. Using your hk as the audio /visual switcher may resolve this issue-and by the way the hdmi cable has audio built in. I hope this was of some help and thanks for choosing FixYa, good luck Prodzilla.
Apr 20, 2011 | Harman Kardon AVR 130 Receiver
In hk avr 2600 there are 4 hdmi outlet. it didnt specify video in or out.
HDMI 1 through 4 are inputs; to the right is the single HDMI Monitor output.
Jul 25, 2010 | Harman Kardon AVR 2600
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
Connecting my wii to my home theater
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
Nov 09, 2017 | Electronics - Others
PS3
Avr 745 HDMI only output 1080i not 1080p. Your PS3 is capable of 1080p. You have to adjust your PS3 to 1080i then your screen will work. I hope Harman will come up with the upgrade for HDMI that can output 1080p otherwise you have to suffer or stuck with 1080i. Hope this will solve your problems.
Oct 14, 2007 | Harman Multimedia AVR 745 Receiver
Harman Kardon AVR 230 Receiver Logo
232 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
