Question about Norelco Arcitec Electric Shaver - Gray/Black
One head is locked up and blade will not turn. To lock and unlock does not work. Can you just replace one head? Is there a solution?
  • Norelco Master
  • 1,610 Answers
The heads on Arcitec models can not be changed individually. You will have to change the whole head. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on May 27, 2011
How do I get my transmission to unlock? It locked when one of the blades fell off. I have replaced the blades.
raise it off the ground get another person the push lever to try to forcse fod in already in then roll when foward backwards hard until engages if hydropump squeels replace pump it will not go into gear with a bad pump
Sep 02, 2014 | Yard Machines 710-1007 Tt Screw:...
Cutter blade remains locked.
when you release the blade, sometimes you have to reengage it manually, turn it to unlock, machine off (safety only) push up on bottom of upper blade until it stops. turn hand wheel and watch if blade is moving. If not repeat. When it moves your good to go.
Feb 15, 2014 | Baby Lock Imagine
How to i remove the head on a Husqvarna 223: trimmer?
The head screws on to the shaft. be advised that it is a left handed thread You should have gotten a locking pin with the trimmer
Turn the blade shaft until one of the holes in the drive disc
aligns with the corresponding hole in the gear housing.
• Insert the locking pin (C) in the hole to lock the shaft.
• UnScrew on the trimmer head/plastic blades (H) in the
direction of rotation
Jun 26, 2011 | Garden
When I turn on my Pilishave razor the blades don't turn. When I open the top, the plastic pieces the turn the blades turn, but when I close it the blades don't turn. What is wrong?
Your blades are either damaged and locking up or they are so clogged with hair that they can not turn.
I suggest that you try to clean them first. If that doesn't work you will need to change them. You will find replacements for model HQ4806 at shaveroutlet.com. See link below for product and disassembly instruction video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Jun 22, 2011 | Philips Philishave Micro Action HQ 4806...
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
Remington 5130 battery is fully charged and when you put it on it goes click. I noticed that one of the heads moves when you try ot turn it on. Removed that head on the unit works great. Put it back it...
It sounds like either the heads are packed full of hair particles and the blades can not turn OR one of the blades has been damaged and is causing it to lock up.
Try removing all of the blades and cleaning them thoroughly and also insoect the blades, particularly the one that moves when you turn it on
If replacements are required, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
Dec 08, 2010 | Remington R5130
How do you replace blades on a 22-540 delta portable planer?
Unplug the machine and crank the head up (open) as far as it will go. Underneath, in the middle of the head there is a bar with two blades on it held in place by a lock bar and six to eight screws. Remove the screws and carefully pull the blade out. The blades are double sided so if you haven't changed the blade before, they can be reversed. Turn the blade around so the sharp edge is out and reinstall it. If both sides are used, install new blades with the blade lock engaged in the channel in the middle of the blade. Make sure to get the screws in tight.
Oct 28, 2010 | Garden
I Locked My Samsung blade 5600 And Forgot My
My samsung blade won't turn on, and just comes up with samsung and then turns off again? help...
Mar 21, 2010 | Samsung SGH-U600
Automatic door locks on 1999 Alero don't work
look for the lock and unlock relays check them to see if they work.what you do is look at relay.look at terminal blades.you have a number 86 and 85 terminals on relay.connect terminal 86 with a jumper wire to positive battery terminal.then connect 85 terminal to ground with jumper wire.if the relay click its good. if not replace it.if relays is good you have bcm problems it control door locks.dealership job.
Apr 30, 2009 | 1999 Oldsmobile Alero
Norelco Arcitec Electric Shaver - Gray/Black Logo
170 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
