Question about Kenmore Washing Machines
We have a Kenmore 70 series model 110 26722693 top loading washer... The punch tab for the relay switch has broken off so that it doesn't go into spin mode because the machine thinks the lis is open.... Question- How do I get the top off so that I can access the switch?
    Problem Solver:
  • 17 Answers
You will need this part# Lid switchNumber:3949238which can be ordered at www.searspartsdirect.com If you have your owners manual w/parts diagram this procedure will be easy. If not, go to www.searspartsdirect.com and search by your model # be sure to include the 110. This is a very easy repair to do. I will walk this thru whilst referencing the items on the parts section. You will need some room to work behind your machine so, shut off the water to the machine, Unplug it from the outlet, and remove the water supply hoses from the back of the machine. You may want to have a pail or bucket handy to catch the water as it drains from the hoses. Move your machine away from the wall to a position that you can comfortably get access to both the front and back of the machine. Find the section called "Control panel" in your illustrated parts. 1) you will need to remove the plastic end covers on either side of the control panel Item #11. They just snap on and off. 2) With the plastic end covers off you will see a screw that looks like it holds part #7 to the machine top. Remove that screw from both sides of the control panel. Make sure that you put the screws where they will not be lost. 3) Grip both sides of the control panel from the front of the machine, and pull towards you. You should feel and hear a click. Now the control panel unit is loose from the machine. You can roll it backwards and off of the top. It can be lifted off of the top but it will still be connected via the wiring harness. Now go to the section listed as "Top and cabinet" 4) Note part #6, lift up on the tab on each one and remove them. They are going to be tight so you will need to use some force to pop them out. Once both of these have been removed the back should be released from the washer. 5) Allow the rear panel to fall back slightly then lift it off the machine. Take note how it slides in for future reference when putting it back on. 6) Now you should be able to see the hex screws #23 that hold the machine top #2 to the body wrap #5. The screws are hex and flat combi-screws, usually 1/4" or 5/16th, so a socket will fit them. Remove both of the #23 screws. 7) lift the top enough that you can gain access to the lid switch. The lid switch is usually snapped into position but you will need to remove the grounding wire screw #23 at the lid switch also. 8) Carefully unplug the lid switch harness and remove the old lid switch from the top. 9) Snap the new lid switch into place, plug in the harness plug, and secure the ground wire with the screw. 10) Line up your top for the screws #23 and re-attach the top to the wrap. 11) Carefully replace the machine rear panel. Make sure it is properly seated at the bottom and flush against the wrap. 12) Now take each #6 spring clip and re-insert it and snap it back in place This should lock the back panel in place. 13) Line up the control panel to the top and push towards the back of the machine until it clicks into place. 14) Secure the control panel with the two screws #6 and snap the end covers #11 back into place. Reconnect your water supply lines to the machine, and plug it back in. And perform a function test. If you did everything correctly, your machine will now operate in the spin cycle.
I hope this helps
Posted on May 27, 2011
Testimonial: "Came apart just as you described... Now if you can just help me figure out how to get it back into balance!!!! JK- Thanks for the help!!"
  • Daniel Morgan May 27, 2011
    Are you referring to the tub balance?
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer will not drain or spin but will fill up how to fix it
The usual thing wrong when a washer such as the one ya have doesn't spin or drain,it's going ot be a broken lid switch. Its a pretty common thing so i have written this tip of how to check for a broken lid switch, http://www1.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
GENE
Oct 10, 2011 | Kenmore 24032\24036 Top Load Washer
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Sounds like a broken lid switch. Easy to fix. Heres a schematic.Its # 11. Try part # 285671. Dave www.washermd.com
Dec 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
187 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
