Question about Uniden EXI 7960 Cordless Phone (EXI7960)
We have an older Uniden cordless telephone-Model #EXI7960 that seems to have a very soft ring tone. How can we increase the volume of the ring? Also, is there an owners manual on-line for download?
  • Uniden Master
  • 5,416 Answers
The EXI7960 has two ring tones and two volume settings available. With the handset in standby, press the Volume up button. (The volume up and down arrows let you switch both volume and ring tone. So you may have to press it a few times to adjust the volume.) The display should show the changes.
Retrevo has the manual here: http://www.retrevo.com/support/Uniden-EXI7960-Telephones-manual/id/471dj498/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
Posted on May 27, 2011
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
Need loudest ringtone possible
To increase the ring volume, press the up-arrow button.
You can also change the ring tone using the Ringer Tones option in the setup menu.
If you need a manual, you may download a copy here.
Mar 03, 2012 | Uniden D16602 Twin Cordless Phone
Can't figure out how to turn the ringer on our Uniden 6.0
You can increase the ringer volume from the menu ... by the way Uniden DECT 6.0 Cordless phone basically have very low ring volume ,,, try using an extra ringer which is very cheap or you can make your self ... A simple circuit diagram available on http://www.electronics2day.com/index_files/Page790.htm
Nov 18, 2010 | Uniden DECT 6.0 Cordless Telephone...
Ring tone - need to set ring tone above two rings. need to set it at 5.
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Sep 08, 2010 | Uniden DECT 6.0 Cordless Telephone...
Ring tone
In most cases the ringer has been inadvertently turned off or too low. You can turn it back on from the system menu and can also try by increasing the volume control while the phone is idle.
May 01, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do I increase ring tone volume?
need model number to answer your question, but you can download the manual here
http://www.uniden.com/index/manuals_results.cfm?cat=1
Jan 22, 2010 | Uniden 5.8GHz Cordless Phone
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
May 14, 2009 | Uniden Cordless Phone
I carn't ajust volume on ring tone
Since you declined to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual. The manual will describe how to change the ringer volume.
May 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Uniden EXI 7960 Cordless Phone (EXI7960) Logo
169 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
