Question about DeLonghi Heating & Cooling
Oil heater electrical wiring diagram - DeLonghi Heating & Cooling
2 Suggested Answers
  • 70 Answers
SOURCE: electric hot water heater
If you can find me a serial and model number i might be able to help you better.
Posted on Apr 24, 2008
I need the diagram
You want wiring diagram? With recommended wire size?
This particular water heater has a factory-pigtail, and is direct-wired into octogon box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Here is illustration:
http://waterheatertimer.org/images/Main-subpanel-Tankless-4a-8.jpg
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
I need a wireing diagram for two elament electric water heater. Mine runs on 220 volt, my question is what about the common or white wire where do i hook it to or do I not need it when running a 220 circut
Links below show specific wiring diagrams and explain 240V with two hot wires vrs 120V with hot and neutral wires.
Then if you have more questions, add a comment and I will fill in blanks:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
First diagram will be for your water heater.
http://waterheatertimer.org/B220C.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 17, 2011 | Reliance & 40 Gal Electric Mobile Home...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
Sep 18, 2010 | Whirlpool Water Heaters
I need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Feb 13, 2009 | Lakewood Oil-Filled Electric Radiator...
ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Aug 27, 2008 | Lakewood Heating & Cooling
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Heating & Cooling Logo
259 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
