Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox refrigerant charge
Do you know how much charge is required. I just got a used skybox off craigs list and found the cap tube kinked and cracked @ the drier. I now have all repaired but would like to add factory charge and found the name plate damaged beyond use.
Thanks
Walter
  • waltervan Aug 17, 2008
    Sorry thats what I meant by name plate was the model/ serial tag it is damaged and unreadable.
  • 770 Answers
I would weight charge it the # of Ounces should be on the model /Serial tag if not let me kow i will look it up for you
Posted on Aug 16, 2008
  • Gary Davd
    Gary Davd Aug 17, 2008
    I have look thru the maual on the unit it does not show a weight charge on it. I can send it to you if you post your email here. The best thing to do is ask someone here who has a skybox the same question they can read their tag for you.
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from maytag skybox machine
Maytag never offered a compressor as a replacement part for the SkyBox. It simply was not cost effective. If you are sure the thermostat is supplying 120VAC to the compressor, then have a qualified service technician install a Supco URCO410 relay/capacitor/overload kit on the compressor. As with any sealed refrigeration system, the US Environmental Protection Agency requires that a certified refrigeration technician recover the refrigerant charge before accessing the sealed system.
I hope this helped.
Maytag skybox dispensing chut
well, the middle 2 chutes are not the same part number as the top or bottom...what is the part number of your assembly? where are you located?
Nov 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
CAN A SKYBOX 'MAYTAG' BE PERMENENTLY INSTALLED OUTSIDE
The Maytag SkyBox is not a commercial vending machine. It is designed for INDOOR use only. The possibility of electric shock is likely from a unit that has gotten wet. In addition, the electronics are not designed to withstand the outdoor elements.
Aug 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox will not get cold.compresser comes on and goes right back off
IM HAVING A PROBLEM WITH MY SKYBOX MODEL#MBV1976AAB, I HAVE HAD THIS UNIT FOR ABOUT 3.5 - 4 YEARS AND NEVER HAVE I HAD A PROBLEM I LOVE IT. LASTNIGHT I FILLED UP THE MACHINE WITH ALL OF OUR FAVORITE BEVERAGES I WOKE THIS MORNING TO FIND THAT IT ISN'T GETTING COLD IN FACT YOUCAN HEAR THE UNIT ON BUT NOTHING IS GETTING COLD. PLEASE TELL ME WHAT CAN I DO I HAVE SPENT A LOT OF MONEY FOR THIS PURCHASE NOT TO HAVE IT DIE ON ME IN SUCH A SHORT WHILE.PLEASE E-MAIL ME AT: ALYSIA.FITZ@YAHOO.COM
Jun 20, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Compressor
cant replace it it is a thow away model go to www.apdepot.com do a search for your model you will see here is the Service Manual check your email
May 05, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox not cooling
Sounds like the refrigerant gas has leaked out. Any reputable refrigeration engineer can fix this.
Sep 30, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
421 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
