Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the right of where the water comes in for washing. Need to shut off the main water lines to stop the dripping.
  • Anonymous Mar 21, 2014
    I have finished washing and the there is a drip at the top of the washing machine
  • 95 Answers
It sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Posted on Aug 16, 2008
SOURCE:
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
I have a whirlpool Heavy duty extra large plus washer where the water will not stop running into it. The only way to turn the water off from entering the tub is by turning off the supply valve - even when...
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 26, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I want whirlphool whasing machine with dryer please give the gideline of it and its price my e - mail ID is [email protected]
Washers are more advanced and stylish than ever before. When you're buying a washer, look for features that make washing easier and more efficient, less costly, and kinder to fabrics. Thanks to advances in technology, it's all possible - and our washer buying guide shows you how.
Washer Types
Feature options, capacity, energy use and style are all factors to consider when deciding between a front- or top-loading washer.
oth top-loading and front-loading washing machines will do a good job of cleaning your clothes. The most significant differences between these types of washers are capacity, energy efficiency, water use, feature options, and style.
Top-loading machines
Traditional top-loading washing machines are available in a wide assortment of models, price ranges and styles. The most basic top-loading washers perform very well and are generally a good value for a no-frills, clean wash. Other top-loaders offer more cycle and temperature selections, spin speeds, and fabric care extras as they increase in price. Overall, top-loading washers are generally less expensive to purchase than front-loading machines, but are slightly more costly to run because they use more water and electricity.
Most top-loaders fill the tub with enough water to cover the clothing, then agitate them to get the clothing clean. Some manufacturers now offer high-efficiency top-loading washers using a number of different technologies. One such technology is the Whirlpool® Calypso® wash plate. Instead of agitating fabrics to get them clean, the wash plate moves them through a shower of concentrated detergent and water. The action is gentler on fabrics; it's designed to provide better cleaning with far less stress to garment fibers. And with the agitator out of the way, the washer has more room to clean bulky items such as comforters and rugs.
Standard capacity for a top-loading washing machine is 12 to 16 pounds per load. The Calypso wash plate model can hold up to 18 pounds of laundry (think the equivalent of 16 pairs of jeans).
Here is a link to some Whirlpool washers for you to look over.
Dec 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Have a year old Whirlpool Ultimate Care II. After wash is spun and load is done the clothes are still sopping wet. Tried extra rinse but that doesn't help. Afraid of damaging dryer when putting clothes...
Check to make sure a nail has not gotten stuck in one of the hole in thew bottom of the drum. Check to see that no article of clothing has gotten jammed between the tubs or the top.
Dec 03, 2010 | Washing Machines
Which washing machine is better front load or top load?
Front load washing machines are better than top load money wise.
One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Water runs back into tub when lid is opened
not sure what you by opening lid and a large amount off water falls in.i think you mean you open the lid and see water there.If thats so two things one your pump is blocked,youll need to confirm by watching whats happing.Other is the water valve is not sealing so water is dripping in all the time.you would see this when standing there be patient
Dec 31, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
