I HAVE A IOMEGA CLIK 40 PCMCIA, 4OMB REMOVABLE DISK DRIVE MODEL C40-72. I NEED APPROPIATE DRIVERS FOR THIS DEVICE. IT WAS A BEAUTIFUL TECHNOLOGY BUT GIOT RAILROADED OUT BY THE RRIVAL OD USB CARD DRIVES. DO YOU KNOW WHERE I CAN GET DRIVERS TO USE THE DEVICE ON WINDOWS 7? APPREDIATE YOUR HELP, THANKS.
which operating system ?
W 7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
W 7
for XP or earlier
It won't open so either your computer drives need updating or your USB Hard drive has been locked some how and I don't know how to unlock it. Hope this helps!?
Go to my computer property then hardware then device maanger then uninstalll usb drivers from it then install again. Then reconnect flash drive then check .If still face problem right clik on my computer icon then go to then manage then g oto disk mamagement then u can see removable drive open it .
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
