Question about Dryers
I cant find a replacement drum for my lg tromm dle5077s. It is cracked.
    President:
  • 3,074 Answers
Http://www.repairclinic.com/LG-Dryer-Drum-Or-Tub-And-Related-Parts
Posted on May 28, 2011
  • Tim Whalen May 28, 2011
    this is cheaper:
    http://shop.ebay.com/i.html?_from=R40&am...
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
With my dryer which still dries well. I get a load thumping noise on its rotation even with no items in the dryer. What would be the fix for that
Look at the inside of the drum, at the seam. At the front or rear side you will probably find a crack in the stainless steel weld. The fix is to replace the drum.
Jun 15, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm dryer has a crack in the drum. Can this be self repaired and if so how?
I'm a mechanical engineer and improvised a repair as follows: rotated drum so that the weld crack was not displaced; roughened surfaces and fitted a small Stanley steel mending plate across crack (shaped plate to match inside drum surface); used PC brand "Fahrenheit" high-temp epoxy putty to bed the plate in place; covered the repair with another thin epoxy layer to provide a smooth surface which would not catch on clothes; further smoothed repair with quick wipe of solvent; most likely a temp fix but working well so far (1 month).
Nov 03, 2009 | LG Dryers
I have a front loader LG Tromm dryer that has a crack in the drum. Can this be self repaired anad if so how? Thanks
I HAVE REPLACED SEVERAL OF THEM. THE ROLLERS CAN GO BAD AND THE TUB IS SUPER THIN. IT USEUALLY CRACKES AT THE WELD IN THE BACK. THERE MAY BE A RECALL ON THAT BY NOW. THE LG COMPANY MIGHT SEND YOU A NEW TUB AND ROLLERS IF YOU COMPLAIN TO THEM ENOUGH. UNTIL THEN ALUMINUM TAPE IS A TEMPORARY REPAIR
Nov 03, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Loud thumping noise has resulted in penny size hole in the drum.
Check your owner manual some LG had life time warranty on there drums..if so call for service..
Sep 21, 2009 | LG DLE3777 Electric Dryer
LG Tromm Dryer Thumps when running
The drum on my dryer is cracked, it thumps the entire time it runs, and it snags up all of my wife's clothes. We hate these appliances!
Aug 14, 2009 | LG DLE2514 Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
