Question about Saeco Aroma Espresso Machine
The fixing of my Saeco Aroma problem
Hi Mirran,
Thanks for getting back to me so quickly. You've said that I need to use a bellow pump or something similar to force the water into the water inlet in the machine........but i don't know what a bellow pump is. What is it and where can I get one? And which water inlet on the machine do you mean?...the tube?
Sorry to sound so dim....hope you can help me understand how to fix it!
Thanks again in advance!
Still coffeeless! xx
  • 515 Answers
Try first this.
Fill the water tank with water, power on the machine.
open the steamknob and press the button for making coffee, if you are lucky you will get water out of the steam pipe.
If you not get any water then you have to press in water with force in the tube you can see in your water tank, the instruction above is the same on this case.
Hope it will help you.
/Mirran
Posted on Aug 16, 2008
Saeco easy
Hi Andrew,
Sorry for the delay, i´m on sick-list and have not access to computer regulary.
Make sure you not get any damp into the grinder.
Try to grind little more coarse to see if the machine will grind the beans.
Have a nice day
/Mirran
Oct 17, 2008 | Saeco Easy Espresso Machine
Saeco Easy
I don´t no what problem Vinnie had.
If you should replace the flowmeter then you can work from the back.
Let me know your problem then i can get you a solution.
Best regards
/Mirran
Sep 28, 2008 | Saeco Easy Espresso Machine
Starbucks Saeco Italia Digital
That was not good you not fixed the machine:-(
/Mirran
Sep 10, 2008 | Starbucks Saeco Italia Digital Barista...
Where can i get saeco coffee machine parts in Australia?
Contact Saeco Australia.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
Best regards
/Mirran
Aug 30, 2008 | Saeco Magic De Luxe Espresso Machine
Primary on off switch won't turn on
Some off the machines have a reset pin on the thermostat, take off the top and you will see the thermostat on the boiler, one off the thermostat have a pin you can press on.
Hope this will help you
Best regards
/Mirran
Aug 27, 2008 | Saeco Aroma Espresso Machine
My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
You're a genius!!!
Love to hear you get your machine to work again.
Have a wonderful time with it and make sure you descale it regulary to get the best out of it:-)
Have a nice day.
/Mirran
Aug 16, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso Machine.....doesn't draw water.
You have to take a bellow pump or similary and fill with water, after that you have to open the steam knob and put force in the water from the bellow pump into the water inlet on the machine.
Hope this will help you, let me know if it works.
/Mirran
Steam nozzle leaking
Hi! hope i'm not too late, since this leaking problem occur's quite often, specially when one's tends to overtight the valve, the proposed solutios will certainly help thousand of happy Saeco owners.
Anyway i happened to live with it but after a second valve replacement, i got fed up with filling too often the reservoir and fixed it at Zero cost. What i did is realy easy:
1- Find a bearing the size of the plunger of the needle valve; the thiny steel ball in a nail polish bottle is what i used.
2- When the electric cord is pulled off the wall outlet, take the cover off, reach to the snap locker and pull it off.
3- Unscrew the needle valve plunger off the cylinder, grind or file the
tip 3/16 of an inch, making sure it is at rite angle cut.
4- Insert the ball in the valve body and push it with the flattened tip
over the vapor down stream and screw. You now have a new valve that will outlast your coffe maker.
Aug 04, 2008 | Saeco Aroma Espresso Machine
Saeco Aroma Espresso pump not drawing water
Hi Espressoless,
You have to force in water to the machine, to this you need a bellow pump or similar and force it into the water tank inlet when you do a priming.
Dec 30, 2007 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
296 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
