Question about Orange Amps Orange Amplifiers Thunderverb 200 Series TH200HTC 200W Tube Guitar Combo Amp Orange
I get a buzzing noise when my thunderverb 200 is idling
  • 1,591 Answers
Turn on the ground lift and/or make sure the unit is properly grounded
Posted on May 27, 2011
  • 6 more comments
  • ross611 May 27, 2011
    my amp does not have a ground lift and it is properly grounded.????
  • Norman Skinner
    Norman Skinner May 27, 2011
    If you don't have a ground lift, you may be stuck. Try different outlets in the house though.
    maybe it is just the filaments from the tubes buzzing?
  • Norman Skinner
    It's possible that one of the tubes may be degraded and needs replacing, but any amp with a grounding issue will hum. Check the unit with no instruments plugged in. If the humming stops, check the instrument and it's cable for loose or missing ground connections.
    the tubes tubes are pretty new and were matched and run in. i have disconnected all cables etc and still that hum. not loud but annoying!
  • Norman Skinner
    Any tube amp I have ever used has some hum when turned up loud with no input.
    It wasn't til we moved over to MOSFETS that I was able to attain full volume silence with no input.
  • Norman Skinner
    Here's a possibility though, check the capacitors filtering the power supply right after the rectifier. Replace them, and upgrade them if possible to a higher uF rating. Make sure you use an equal or higher voltage capacitor, and be sure to note the polarity when replacing it. This can actually help a lot, especially if the filter cap has degraded.
    i would do that but the amp is only about 6 months old!
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 | Music
Buzz coming from elec. guitar pickups only when using Aviom and headphones
It is a definite pickup grounding issue causing hum/"buzz" which diminishes when touching strings. Check the impedance of cable jack inputs and cable which should be 1/4"mono input/output jacks) . A personal preference but effective is to NOT run guitar direct into mixer but through an external amp w/ a headphone out jack . Noise gating/preamp filter also will help eliminate the "buzz"/noise from pickups. It is unfortunately the nature of the "electro-magnetic" beast when it comes to electric guitar pickups .Hope this helps.
Feb 23, 2014 | Aviom A16ii Personal Monitor Mixer 16...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
May 04, 2011 | Randall RH50T Tube Series 50-Watt Guitar...
Hope you guys can help... I have a laptop Karaoke system. I connect from laptop to 6 channel mixer to speakers. I use a stereo phono to RCA from laptop to mixer. I am experiencing a buzz coming through...
Yep! Get a decent audio interface that attaches to the PC with a USB connection and uses BALANCED lines to your mixer. I use a UA-25EX Roland/cakewalk as an example. (about $200 and there are cheaper units such as M-Audio Fast Track MKII ) Note these interfaces BOTH record and playback with two channels for stereo.
Essentially the audio board that is in PC's and Laptops are too near the switching noise of the processor and some of that is just bound to get into the audio lines as they don't even have balanced audio lines from the computers. Make sure you use either TRS or XLR balanced cables from whatever interface you get. Also connect ALL interconnected equipment to the same power source or receptacle. You can try to reduce the buzz with the mixer EQ's with what you have, but that sacrifices audio quality.
Mar 30, 2011 | AMP Speakers Pro Karaoke System
Whenever I use one of the cleaner amp models i get an aggravating buzz. The buzz only occurs when I play and is not constant. (The buzz is not there when I'm not playing). At first I thought my strings...
Try moving your guitar around and oriented differently as it MAY be picking up magnetic fields from equipment in the area. Some pickups really are sentive to interference.
The effects for modeling MAY have a noise gate that requires a certain signal level before unmuting which would explain why you have to be playing to open the gate and hear noise that is really there all teh time but muted.
Dec 27, 2010 | Line 6 POD HD500 Amp Modeler and Multi...
Some of my frets do not make any noise when i play them, could you please tell me why this is happening?
You should have NO fret noise if the neck is properly adjusted for string height. If you are getting fret buzz take it into a gutar shop for adjustment.
Google "fret buzz"
Jul 28, 2010 | Fender Squier Std Strat Mn Car
I have a buzzing noise coming from my Marshall AVT100. It is present on all the channels. Is it likely to be caused by the valve? The valve inside is made by Electro Harmonix and it was made in Russia....
okay so buzzing noise. i have seen this once before. the extension cord feeding a power strip with two amps plugged in and powered on off of a low amp electrical outlet with fluorescent lights overhead.......try running only one power unit off of the electrical outlet you are using, just one straight into the wall with the lights out. if you still hear it i wonder if the output transformer is starting to go south. if you listen close sometimes you can hear the buzz of a transformer powered on, example: you can hear the buzz of a power transformer on a power pole in peak hours. tubes usually make hisssing, crackling type noises. next would be to tap on the tubes while in play with an orange stick or pencil eraser to listen for microphics or the tapping itself thru the speakers. if you hear with out a doubt change them.
Apr 05, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Orange Amps Orange Amplifiers Thunderverb 200 Series TH200HTC 200W Tube Guitar Combo Amp Orange Logo
143 people viewed this question
Top Orange Amps Music Experts
Vito Vacirca Jr.
Paul Bade
Michial Gueffroy
Are you an Orange Amps Music Expert? Answer questions, earn points and help others
