Question about XFX GeForce 6200 Graphic Card
Vedio controller GeForce 6200
Hi......Ihave vedio controller GeForce 6200. but I cant install its software because I missing driver CD
  • kory_reham Sep 01, 2008
    i have the same proplem
  • jingnesh953 Nov 02, 2008
    XFX GeForce 6200, Graphic Card video not working
    (AVI.DIXI.3GP. & ALL FILL NOT OPEN )
driver dowunload
Posted on Oct 03, 2008
    Master:
  • 377 Answers
I......Ihave vedio controller GeForce 6200. but I cant install its software because I missing driver CD
Posted on Oct 11, 2008
Installed new geforce 6200 pci graphics,onboard graphics out,no graphics
Go to control panel then device manager then eliminate the drivers for your old card and the new one as well restart computer. Run the driver install if prompted to do so. Hope this helps
Jan 12, 2014 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
My driver cd not installing video drivers on windows 7 for the geforce 6200 say xp or vista
You can go to the evga website and download the windows 7 Drivers.And install them . the web site does have windows 7 drivers for that card.
May 16, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Hi, I have an EVGA GeForce 6200 AGP, 256MB DDR2
This is a common problem, you need to clear the CMOS which will also reset the BIOS settings. Here's a few ways you can do that:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
Feb 22, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
My cd of graphic gf 6200a is lose
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Nvidia GeForce 6200 AGP Graphic Card
My sound started crackling on my GeForce 6200
try to lower the volume in the volume control panel in the start menu
May 23, 2008 | XFX GeForce 6200 Graphic Card
XFX GeForce 6200 Graphic Card Logo
1,388 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
